  • Replies 40
i ordered a brand new n1 block today actually its in melbourne and gonna be here in 4 days or so hopefully :( not sure if there are any others left or not.
not cheap but when u want big power u gotta pay.
i dont think putting $50k into a china safe is a smart idea so im doing a n1 block to replace the 05U block :( buy the best safe then start putting money in it is a much smarter idea.
my 05U cracked after 1200km of use with the new setup. not happy at all, but this means the new block wont limit power output for a long while yet.
No - just the same tuner
do u even know where it was tuned at ? im using the autronics by the way so u can guess who it wasnt :wave:
i got the djetro sitting aside and if i use that ill use who u are talking about but i am keeping autronics at the moment and ive found a good tuner so i dont need to sell it.
why bring workshops into it anyway?
Edited by CruiseLiner
Chill man - only having a stir. :D
The crack is in a known weak place (as you say) and actually is more a function of the balancing and revs that the engine sees. In my case it was caused by poor harmonics and high revs. Was certainly a deciding factor in me spending the $$$ on a full counter weighted crank, ATI damper and close attention to balancing.
no worries gav i am just over all the workshop battles and so forth in perth its annoying as no one agrees on who is good and bad, etc its a losing battle i just keep my mouth shut now :wave:
Chill man - only having a stir. :cheers:
HI Gav, this comment sparked my interest. The block cracking I have seen has been vertically, up the water jacket. I haven鈥檛 seen one go along the block. Which way did yours crack?
:blink: cheers :P
for us visually challanged people can someone point out the crack on that pic?
under the central bottom right hand bolt.... EDIT: Guess not. one day... I still want my questions below answered... please...
I think...
and because I really don't know, couldn't it be fixed? unfixable? weaker (how much)? and could bracing help prevent it happening?
Edited by ebola
:( cheers :D
It was a while ago and I don't have a very good piccy, but I think it was at the top of the rib in the red circle.
Edited by Gav
Hard block that hole, and that particular water jacket, run and external high pressure feed straight from your oil pump and you will go along way to solving the problem of cracked blocks!!!
The rusty water runs down the block due to gravity. So look for the highest point of leaking water, you can see the hairline crack going front to rear.
:( cheers :D
Last year you could pick them up no problems. You cant do that anymore as production has stopped in Japan and there are none left in Australia, and very rare and expensive in Japan now.
I have just found out about this.
I can still buy N1 blocks out of Japan and they are still being made.
You can still get the Nur block aswell which you can tell because of the x in the right corner after the engine number.
And also the GT block is still being made and has a 4 month waiting list :
Which is 5mm taller then an N1 block and 3mm thicker walls than the N1 block.
Bring a bunch into Australiua then as I know quite alot of people who are after them.
For the past 2 months it has been virtually impossible to get hold of one. Everyone promises the world yet cant deliver.
I think you have been misinfomred.
N1 blocks are still unavailable in Japan. If you can get them...I will have ten please.
Also, the GT block is not 'taller' than the N1 block. How do I know? I've had 2 sitting beside each other. Interesting that you say there is a waiting list for the GT block. Maybe if they get another lot of 300, they will make another run.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
