They didn't seem to keep this car long, Seems a little bit dear compared to others on the net, but then again they don't look anywhere near as sexy as this one - nor are they as modified :(
On Car Sales
They had it for well over a year!!!
Id buy it!
Makes me regret my car now!
if you add up what has been spent it doesn't seem to overpriced to me.
for example:
9k = car
5k=bodywork
2.5k=wheels/tyres
say...8k=engine (labor+parts)
2k=susp
2k=turbo
1.5=powerfc
that's probably not everything but it's already totalled way more than 24k
i'm in no way affiliated to the owner and that's just a rough guesstimate, i don't think it's too overpriced at all.
obviously HPI would have recieved benefits for some of the things (labour/parts) however it seems to be a pretty solid car to buy into.
Edited by R32gts-t
for example:
9k = car
5k=bodywork
2.5k=wheels/tyres
2k=susp
2k=turbo
1.5=powerfc
Have you tried to sell an extensivly modified import in the last 12 months?
I refer to my mate having trouble selling a clean manual T67 equipped
Soarer for 12.5k, and this-
http://www.skylinesaustralia.com/forums/in...howtopic=117850
If it was rego'd perhaps it would make a little more sense.. Its still running an RB20 box I believe. Also most of the parts they have fitted aren't the more expensive brands. Though that won't matter to some.
Edited by Drift_Limo
89-90 R32 GTRs with upgraded turbos and 400rwhp+ sell for this price though, and even cheaper....
Very unique ride however :action-smiley-069:
aka timebombs :wub:
I think everyone wants something for nothing these days, seems reasonably priced to me, that RB24 would have cost a bomb to build, mates rates or not.
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
