R33 will be a pull type gearbox... R32's are push type.... (well late R32's will be pull type, so are exactly the same as R33 gearboxes)....
look at where the slave bolts onto the bellhousing and where the hole for the clutch fork is. if the slave bolts on on the rear side of the gearbox (near the hole for the clutch fork) then its a pull, if it bolts on in front of the hole, then its a push.
r32
08/89 -> 08/91 32010-05U10
08/91 -> 02/93 32010-05U11
02/93 -> 32010-12U00
32010-12U60 is listed as alternative part number for 32010-05U10
my version of fast crashes when you try and view illustration for r33 gtr, hope this helps.
Sorry...but i would like to know if a GTR33 gearbox would fit into a 1990 GTR32? If not, wot work needs to be done to fit it in and is it likely to cost a lot?
Anyone can help?
Huh? Duncans post clearly says
You may need to convert from pull to push type if you want to keep your old clutch
So... umm, yeah you would need to convert if you want to keep your old clutch
To convert it you need some parts from an push box (your old one if its still around), you change the pivot point and tap the casing to swap the direction of the slave cylinder, the casing should have the right points cast into it but no thread.
About 1hr work for a competent workshop once both boxes are out.
If you want to fit the box you have in the pic, it's a traight fit, it's a push clutch box.
If you want to use a later model pull box and use a push clutch , like Duncan said use your old fork, pivot and slave and tap the housing, its easy , it has the flat spot there so you can't go wrong..
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
