hey guys, my car is running extremely rich and is in need of a re-tune. I was wondering if anyone knows any good tuners for the wolf 3d v4? Preferably within the north/north western suburbs, but willing to travel anywhere in melbourne.
cheers, Miguel
https://www.sau.com.au/forums/topic/126978-wolf-3d-tuner/
Rank Rotary, only decent Wolf tuner in Melb that ive seen to date, and they have been solid at it for many years now.
Bit of a drive though unfortunately.
http://www.rankrotary.com.au/
Address:
Factory 1 48-52
Shearson Crescent
Mentone VIC 3194
But hey, i would drive 100km's if it meant a good tune without issue/hassle/headache :wave:
https://www.sau.com.au/forums/topic/126978-wolf-3d-tuner/#findComment-2345272
I have been Dealing with wolf3d ecu's for about 3.5 years now
Either take it to pete @ Rank rotary always done well by our customers or i would give rob @ sabbin a go as he knows what he is doing.
all other workshops mentioned have "attempted to tune many cars for me and none have been sucessful. and just because they are a wolf 3d dealer does not mean they know squat about tuning or the ecu
https://www.sau.com.au/forums/topic/126978-wolf-3d-tuner/#findComment-2349282
hey guys those that are recommending sabbadin, do you guys actually have wolfs tuned by him? got my exhaust done there and was very happy with it. no doubt he does quality work but is he a good wolf tuner? or are you guys assuming he is good because he is with everything else?
https://www.sau.com.au/forums/topic/126978-wolf-3d-tuner/#findComment-2374571
Yeah mate I have wolf in mine and very happy with the tune, no hicups car runs fine.
He pretty much only use's wolf in his car's but will tune PFC or anything else happily.
https://www.sau.com.au/forums/topic/126978-wolf-3d-tuner/#findComment-2382318
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
