OMFG that stagea is out of control, i think i just fell in love :D
You are a champion, congrats with putting together such a car, and sticking with it when i know there would have been many times were you would have loved to just give up and walk away.
Glad you are happy with the result, its always good when you put so much hard work into something and you can finally stand back and look at the end result and enjoy it as much as you can becuase you know you made this car what it is.
Congrats to you :(
Simon
thanks everyone for the comments its finally something sorted after sooo long on the drawing boards :)
the tune was done in rwd because im running the autronics ecu and i havent hooked the 4wd up as the last tuner stuffed the wiring and it was wrecking the tps signal to the ecu because they didnt have a clue what they were doing. so i removed the front tailshaft and have been thrashin it around in 2wd for the past few days. its even good in the wet, its like 2 cars in one, makes stuff all power upto 4200rpm or so and then bang its constant wheelspin upto 9000rpm :( the rpm range is huge and with a good power band from 4500rpm-9000rpm makes it awesome for pulling power. it manages 230kmh in 4th gear at 9k rpm (4.3 diff ratios).
i took it out last night in the wet and damn its soo fun ripping donuts on fullboost :D never had sooo much fun in years.
Stasis the mods list is pretty long but heres a run down on what its got at the moment. price for the build is alot ;) JUN gear aint cheap thats for sure. heres a page i made with all the details on the whole conversion i did and engine build, etc http://www.cardomain.com/ride/2400656
Engine: RB26DETT
INTERNALS:
JUN 2.7L stroker kit
JUN forged crank
JUN forged connecting rods
JUN cosworth forged pistons
JUN oil pump
JUN head stud kit
JUN big end stud kit
JUN 272 degree/11.35mm lift cams
JUN adjustable cam gears
JUN titanium retainers
JUN heavy duty valve springs
Nismo bearings
HKS metal gasket kit
Tomei valve guides
Gates timing belt
n1 waterpump
INTAKE:
HKS T04Z (0.81) turbo
K&N pod filter with 6" inlet
Trust stainless steel exhuast manifold
custom 3" aluminium intercooler piping
HKS 50mm external wastegate
EXHAUST:
3" dump pipe into 4" exhaust, to 3.5" after cat
4" magic cat converter
3.5" stainless steel muffler
2.5" rear muffler
FUEL SYSTEM:
sard 1000cc injectors
sard dual entry fuel rail
sard adjustable fuel pressure regulator
bosch 044 fuel pump
goss intank pumps x 2
DRIVELINE:
custom twin plate clutch
gtr 5 speed gearbox
GTR rear diff and axles
4.3 diff ratios
SUSPENSION:
bilstein shocks
whiteline springs
whiteline/arc swaybars
BRAKES:
R34 gtr v spec front 4 spot brembo calipers
DBA 328mm alloy hat slotted rotors
R32 GTR rear 2 spot calipers
DBA 300mm slotted rotors
brembo front brake pads
bendix ultimate rear pads
stainless steel braided brake lines
OTHER ENGINE BITS:
Autronics SMC ecu
Autronics CDI ignition amplifier
MSD coilpacks
nismo engine mounts
nismo gearbox mount
custom 9L baffled sump
got a busy week or two doing a few changes to the setup now. the stock gtr cooler is going to retire and im getting an Apexi drag cooler 140mm thick :D and im chucking in 2x bosch 044 fuel pumps, twin fuel lines from front to back with a surge tank setup as well. exhuast is currently shocking and only running a 3" dump pipe and a 2.5' rear muffler which is chocking it big time. gonna goto a 4" dump pipe and a 3.5' rear muffler to replace the tiny 2.5' thing.
then the boost is going to a respectable 16-17psi for the time being and then ill drive it for a while and then back for a big big boost tune to see what it can really do :)
heres the last video i got, we turned the lights out to show the flames and glowing manifold after a big thrashing. the video doesnt show all the flames because the camera was too far round the side of the car but it shows a couple and then at the end the manifold after the 5 power runs or so as its glowing like mad :)
the sound at 9000rpm doesnt come up good on the video but ill be sure to take a proper video camera next dyno tune and record the sound in better qaulity as it seriously screams :P
cant wait to surprise some unsuspecting v8 drivers on the streets
i think thats about all at the moment :)
happy veiwing
Brad
Engine: RB26DETT
INTERNALS:
JUN forged crank
JUN oil pump
JUN head stud kit
Nismo bearings
Tomei valve guides
Gates timing belt
n1 waterpump
INTAKE:
EXHAUST:
2.5" rear muffler
FUEL SYSTEM:
bosch 044 fuel pump
DRIVELINE:
gtr 5 speed gearbox
4.3 diff ratios
SUSPENSION:
bilstein shocks
whiteline springs
BRAKES:
OTHER ENGINE BITS:
Autronics SMC ecu
MSD coilpacks
nismo engine mounts
nismo gearbox mount
happy veiwing
Brad
CCCOOOOLLLL!!!!! :PBJ: Yea man go smoke some holden and ford drivers man,
Nice work brad love the exhaust flames, your hard works really paying off.
Two wheel drive is so much fun, tried to teach the misses how to smoke the wheels yesterday she nearly ran over the dog.
stagea - tailshaft = :wave:
Top stuff Brad,
Very, very impressive! After all that time, effort and investment I don't think my nerves could take the power runs on the dyno, but I guess that's what you built the beast for!!!
Fortune favours the brave, I want to see it down the 1/4 that will be the real deal.
Cheers
Luke
well done champ...would have commented early but havent been able to use the computer since MrGTST has been on it non stop-- :P
well done really on your effort, it really is a beautiful sleeper!! :O
Top effort buddy catch up soon for a looksie ok?? :O
luv wildcat...
p.s--swap ya??? :O
Thanks for the PM Brad, all I can is awsome. That is a fantastic number considering your exhaust set up and the very low boost level. It'll be an absolute animal on your final boost setting.
Have a ball with it mate, you deserve it.
Ken
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
