Where To Go For Pumped Guards; Any Contacts?
Hey guys I’m looking to buy an r32 gtr and it looks like the shop who’s done some work on the motor was done at Fujii Dynamic in Japan. Looking to find if anyone is familiar with this shop since there not much info I could find. All I could find was the owner has passed away early 2000s and had previously owned a 1000hp r33 for drag racing.
GTR front looks good. If you don't like it, I'll swap you a rolling shell R33 for it. Give you a fresh base to start with.
soon I also prefer the old look. At least I have more clearance for wheels up front now.
Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
