Thinking about pumping out all four guards on the 34 to accomodate some wider wheels and get a beefier look... been quoted around $1k including spraying from a prestige panel beaters in the local area... was just wondering if anyone here has any reccomendations or advice?
So if you have photos, experience with this type of body work, do's/don'ts please kindly post them up.
Looking at getting this done in a month or so ;)
Thanks
Stan
  • Replies 45
Hey maybe you're right and the rears are the same :( Mmm, does anyone have any contacts?
BTW Steve, cheers for that contact yesterday... called them up and sorted out those fittings - they'll be delivered to me today (not expensive either)
thats a bad example of the Z Tune dude they got different guards then GTRs... rears have the attechment lips and fronts are slightly wider and have that stupid looking edgy top part.
I had a pair of genuine front GTR guards but sold them for $600.
For fronts you could save some dough and get fibreglass ones as opposed to GTR ones.
Would make the car lighter too.
However I know they're made for 32 & 33 but not sure for 34.
There's always GTR front guards on Yahoo Japan. Some need a bit of filler and a respray but that's par for the course and you were going to respray them anyway. These are the best option for the front.
The rears are doable with factory rear quarter panels as well but you're basically going to have to respray the whole car that way. There's been a bloke trying to sell a GTR rear quarter panel on Yahoo for a couple of weeks now he's only asking 40,000...
The GTR rears are significantly different to the GT-T rear guards...
I've been looking into this too, Stan, and cannot seem to break the 1G quote for getting front and rears pumped. That does seem like the best solution, though.
Someone was actually selling a set of fibreglass GT-R guards on ebay modified to fit a GTT last week. Sold for like $600 or so I think.
$1k was a ballpark figure I was given last night when I made an enquiry with the shop. Given that they do European cars mostly (repairs to BMW M3 guards) they would be more expensive but have the right tools and experience.
I'm going to have a hunt around, will post up if I find anywhere that's a little lower but of the same quality.
Why dont you buy the guards, and spray them and fit them at NBP?
You guys have the spray gun dont you? I think i remember seeing something like that when i was there
That way the cost should be HEAPS lower
LOL Steve, spray painting is the one things we WON'T do even if we have the gear.
I'll shop around; can anyone confirm if the GTR guards will just bolt on or will they need modifying?
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
