I'm thnking of getting one of these systems...
If someone has one, how loud is it? db? Soundfiles would be awesome!! Is it stainless or coated/painted mild steel?
I know Fujitsubo exhausts get a great rap on these forums. Just wanna know if this has a good rumble to it, I currently have a Nismo stainless catback that barely sounds different to stock. I want the trademark RB rumble low down and the nice bark up top. Currently it just sounds like a blowing noise.
I'd prefer something like the Kakimoto twin pipe/canon catbacks but cannot find one anywhere. If anyone has one or knows where to find one please let me know.
https://www.sau.com.au/forums/topic/127064-fujitsubo-twin-pipe-catback/
Thats the same exhaust I have, not only that, I think its the actual photo of my exhaust if you took it from the Option 1 Garage website.
Its pretty quiet
It might actually be a pic of your exhaust :) I found this pic on the forums while I was looking for info on the one I'm considering.
Do you have any means of recording the sound? I'd love to hear one. Do you have anymore to add in terms of a review?
In terms of review, I would say it looks nice and sedate, and sounds the same too. It does have a hint of the RB rumble, but nothing like you would expect from say an A'PEXi N1.
My Digicam has a sound recording feature so I'll try to get a recording tomorrow.
Do you know if they're still selling these? I was pretty sure Fujitsubo stopped making them?
Heres a photo of the exhaust on my car
Edited by MintR33
hey dude its sidd..
i think i know someone who might have a dual exhuast system for sale.
I will go in tomorrow and check with him!!
hmm ya i think thats the one he had.. Pm you tomorrow sometime.
Edited by siddr20
Here you go mate, just took a recording then. Actually dont think it sounds too bad after hearing a recording :P
Thanks mate! It sounds pretty good. Definately beefier than mine, but maybe not quite enough :)
Sidd, I look forward to hearing from ya tomorrow!
Allblitz, depending on what Sidd says tomorrow I might have to take you up on that. My only thought is that gtst system splits after the flange on the cat, whereas the full twin would run two cats. Is that right?
Just thought I'd let you know some guy is selling the same exhaust mentioned in the first post on ebay: Link
He's talking it up a bit tho, doubt he would have paid $2800 with a trade discount as option 1 garage let me have mine for $900 as a couple of flanges went missing when it was shipped to Australia.
Thanks dude, that was actually the one I was thinking of getting. I've spoken to him about it quite a bit. I appreciate the thought though!!
Lucky for me.. I have sourced a "Kakimoto Hyper2000 FullMega N1+Dual" as pictured above. (Just love how Japanese the name sounds :happy: )
So I'm sure the line will be sounding a whole lot beefier on Monday.
Thanks to my boy Sidd for the hookup, and thanks for all the replies.
that ebay seller talks a lot of bullshit about his parts. I actually bid against him on some stuff on yahoo japan only to see him then list it (after beating me) on ebay with a whole bullshit story about how they were parts he bought brand new (rubbish) for his race car, etc ,etc... plenty of lies and plenty of mark-up too.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
