  • Replies 43
All cars are different - benm's gtst wasnt ALL driver ability - I didn't do much better than ben himself in that car (ben can you remember the numbers?).
low 13's for 200rwkw sounds about right to me for street tyres. I went 12.9 on regular streeters with 190kW and 12.6 on drag radials with no other changes. Suspension in the rear that is too soft is bad too. I have very stiff suspension set up for that type of racing yet it will still 1.66 60'.
benm - I'm DYEING to drive your car! lol
Adrian
Not forgetting that some R33's are getting to be 13 years old now, those numbers you see for the qtr mile quoting were often done when the cars were near brand new.
Having said that, I had:
R33 Gts-t, 93'.
Catback exhaust, apexi pod and lightened flywheel.
My first time at the drags ever, I had three runs and my best was a 14.4.
I was plenty stoked with that time, to be honest I really wanted to beat 14.5 so I was happy.
I'm sure with more practice the I could have run better, but yeah.
My 2c is that driver ability is going to give you your greatest time advantage at the track.
Edited by insu
Eh, boys, u been a great help. Its amazing how many diff opinions are out there.
Ive decided im gonna set boost to 9psi, dyno tune and see how close i get to running a flat 14 with full exhaust, FMIC and POD.
I'll post up the results for all to see
Hopefully I wont lean it out or blow the turbs, as has been suggested by some
I did 14.5 @ 95 with just a cat back - now I have FMIC, full exhaust and bleed valve at 10psi so hopefully I should see 13's!! :)
I was doing 1.9 60 footers too - so thats gotta count !! hahahaha
There isn't really much point "dyno tuning" with the stock ECU, as there is nothing to "tune".
Just get a boost gauge and a bleed valve, head to the track, run it on the stock boost to get a base time, then wind small amounts of boost in until you get to 9psi and see what difference it makes.
the ageement is that low 14's / 14 flat is pretty much stock territory, if it's nicely tuned. If you have a full exhaust things go better and into 13's.
Just go drag racing anyway. It's easier to learn with a car that has a little less power, you will find wheelspin is enough of an obsticle even stock. The more practice you have the better you get anyway. Learning how to best get your car to do the 1/4 takes time, oh.. and breakages.
Edited by rev210
Good suspention and tyres will make a huge difference no good having power in you cant get it to the ground. gts25t runs 14.4 in factory form so get a good set of tyres, suspention exhaust and intake and a 14 flat may be possible
Okay - someone give me their STOCK R33 gtst and i'll put MY tyres on it and we'll see what's what.
I reckon 14.0's.
    • Is it a dog or synchro box? I guess either way, if it is new and crunching in one gear only, it has to come out and go back to the shop to check/measure as there is either an assembly or manufacturing issue
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
