carrillo's just seem a huge step up... i mean there's the 350rwkw and then there's like the carrillo's at 600rwkw... we need to find a 450rwkw rod. 350rwkw is easy to reach with a 3lt block and 450 is a happy medium, high enough power to be very reliable, but not so high that you are spending mega bucks
  • Replies 53
yeah i'm interested in the chevy ones too... i think that carillo rods are a bit beyond what i'm aiming for. I'm going for plenty of low-mid range power rather than all out topend. And once you pass the 320rwkw or so, the gearbox and other parts start to need looking at and i can't afford to do that!
Ah well Im aiming for 450rwkw at arounf 1.0-1.2 bar, If i get power hungry I want to make sure I done need to gringe every time I give the car a boot full, so Carrillos are the way I am going besides at around $1100 + machinng which is around $600 your not far off $2,400 for the carrillos, and if you do ever need to rebuild you can just buy one carrillo not 8!!!
The 2.5, 2.6 and 3.0 rods are all different in length. You will need to decide what capacity you want the 3.0 will make the same power at lower rpm and it will tend to last longer. If you go 3 litre then I assume as you, me and GiHOr33 will want RB30 Carrillos we will get a fair discount
Jordan
Update: Ive was given a hint. I found Oliver rods they said that they would suit a supercharged small block making 1100HP at 8,200 rpm. This is the same cylinder presure as a RB30/31 making 750/800Hp so hence they say these will do they are $125 US a rod which makes a set $1,500 Australian, allot cheaper than Carrillo what i want to know is how good they are, maching to make them suit will cost around $400 i guess so $1900 all up
Sydnekid or anyone else know about these rods and how good they are???
GR8NES/700
Hi GR8NES, what do I know about Oliver...........
* Oliver make good stuff, been around a long time
* used a lot in Nascar
* the rods are "I" beam
* they come standard with ARP rod bolts
* I think it's Trust that sell rebadged Oliver rods (and charge twice as much)
* they make forged and billet rods in three weights, standard, lightweight and super lightweight
* a set of 6 light weight, forged "I" beam, unmachined rods with 7/16 ARP 8740 rod bolts should be around $A1200 plus freight
* for about $A15 per rod extra you can upgrade to the ARP 2000 3/8 rod bolts
* my personal preference is their standard weight, billet, "I" beam, unmachined rod with 7/16 ARP 8740 rod bolts. Used them in a couple of Chevy speedway engines, no problems.
Never used them in a Skyline engine, but no reason why they would not be OK for the job.
Hope that helps.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
