carrillo's just seem a huge step up... i mean there's the 350rwkw and then there's like the carrillo's at 600rwkw... we need to find a 450rwkw rod. 350rwkw is easy to reach with a 3lt block and 450 is a happy medium, high enough power to be very reliable, but not so high that you are spending mega bucks
  • Replies 53
yeah i'm interested in the chevy ones too... i think that carillo rods are a bit beyond what i'm aiming for. I'm going for plenty of low-mid range power rather than all out topend. And once you pass the 320rwkw or so, the gearbox and other parts start to need looking at and i can't afford to do that!
Ah well Im aiming for 450rwkw at arounf 1.0-1.2 bar, If i get power hungry I want to make sure I done need to gringe every time I give the car a boot full, so Carrillos are the way I am going besides at around $1100 + machinng which is around $600 your not far off $2,400 for the carrillos, and if you do ever need to rebuild you can just buy one carrillo not 8!!!
The 2.5, 2.6 and 3.0 rods are all different in length. You will need to decide what capacity you want the 3.0 will make the same power at lower rpm and it will tend to last longer. If you go 3 litre then I assume as you, me and GiHOr33 will want RB30 Carrillos we will get a fair discount
Jordan
Update: Ive was given a hint. I found Oliver rods they said that they would suit a supercharged small block making 1100HP at 8,200 rpm. This is the same cylinder presure as a RB30/31 making 750/800Hp so hence they say these will do they are $125 US a rod which makes a set $1,500 Australian, allot cheaper than Carrillo what i want to know is how good they are, maching to make them suit will cost around $400 i guess so $1900 all up
Sydnekid or anyone else know about these rods and how good they are???
GR8NES/700
Hi GR8NES, what do I know about Oliver...........
* Oliver make good stuff, been around a long time
* used a lot in Nascar
* the rods are "I" beam
* they come standard with ARP rod bolts
* I think it's Trust that sell rebadged Oliver rods (and charge twice as much)
* they make forged and billet rods in three weights, standard, lightweight and super lightweight
* a set of 6 light weight, forged "I" beam, unmachined rods with 7/16 ARP 8740 rod bolts should be around $A1200 plus freight
* for about $A15 per rod extra you can upgrade to the ARP 2000 3/8 rod bolts
* my personal preference is their standard weight, billet, "I" beam, unmachined rod with 7/16 ARP 8740 rod bolts. Used them in a couple of Chevy speedway engines, no problems.
Never used them in a Skyline engine, but no reason why they would not be OK for the job.
Hope that helps.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
