Hi GR8NES, as far as I know Oliver sell over the internet, so you should be able to buy them that way. You really need blanks (unmachined), I'm not sure whether you can order them that way on the web site, you may have to talk to their tech support.
Why 6.125 inch rods?
  • Replies 53
Hi Jordan, a 6 inch rod is 6 inches between the centres (big end and little end), a 6.125 inch rod is 6.125 inches between the centres. You can't have a 6 inch Carillo that is 6.125 inches.
This is an old thread, but if u guys are after a 6" rod, thats chev 350 territory. Its longer than stock, but alot of people make em, and u wouldn't need to pay $2400 for em thats for sure.
6.125 would be a mopar.... 360 from memory rod.
And a smaller rod than stock dosn't give u more displacement, the rod is still moving the same distance. It DOES realllllly kill ur compression. Rod no longer reaches deck height, thus theres a huge gap between the top of the piston and the combustion chamber, thus ur CR is killed.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
