now for the sale, i have the following on offer.
1) 2 x s15 rear bars ADM in very good nick (black and blue)... $80 each ono
2) S15 rear rear cradle wercking...
-camber arms $150 pair
-lower control arms $180 pair
-other "arms"... make me offers
-or the whole cradle minus diff, driveshafts and hubs $500
3) s15 door tirms in perfect condition... $250 each or $450 pair nego
4) s15 passengers side door shell in blue... $250 in very very good condition
5) s15 mirrors in blue... $100 the pair in excellent condition
6) s15 drivers airbag.. $200.. passengers.. $200... control module $250... or all together $550
7) s15 engine mounts... $50 each or $90 the pair
7.5) s15 clutch standard item with plenty of meat left (flywheel included) $200
8) cefiro seats front and back... very rare colour kinda greyish brownish.. cef owners should know what im talkin about... in excellent condition... $250
9) cefiro crossmember will bolt any rb engine into a silvia complete with engine mounts... $250
10) cefiro stock front and rear bars in good condition in silver... $100 each
11) rb20e engine in very good condition... free (pickup)
12) rb20 gearbox either de or det not sure in very good condition with flywheel and clutch $400
13) Rb20 tailshaft yoke only... $50
13.5) cefiro steering rack non hicas... $200
13.6) cefiro tierods $100 pair
14) s14 crossmember... $200
15) s14 steering rack.. $200
16) s14 tierods... $100 pair
17) S13 side skirts $50
18) SR20det inlet manifold complete with injectores and throttle body $100
19) SR20de complete engine great condition low km's $200
20) s13 standard rear camber arms $40 pair
21) s13 standard rear toe arms $40 pair
22) s15 air con compressor like new $100
23) CA standard intercooler $40
24) s13 standard rear bar two tone silver $80
Aftermarket parts
1) work meisters 18x9.5 (+38) 18x11 (+41) with "drift spec" rear tyres and semi decent front ones in gold.. (has some gutter rash)... $2300 ono
2) HKS camp system.. display vehicle revs.. speed... etc anything from the ecu on your tv screen (not included).. comes with HKS remote.. ... $300
3) greddy emanage with main harness... $350
4) s13 ganador mirrors one side come apart... suit diy fibreglasser... $130
5) tomei exhaust temp gauge black face... $60
6) greddy oil/water temp gauge... electronic.. needs sender... black face... $100
7) s13 apexi mild steel 3" catback exhaust including resonator but not the muffler... $150
theres prolly somemore stuff i forgot to mention but ill post them up as soon as i find any new stuff.
ALL PRICES ARE NEGOTIABLE!!!!!!!!!!!!!!
do not hesitate to contact me via pm or on 0416734388
kinda regards
https://www.sau.com.au/forums/topic/127133-various-nissan-parts-a31s13s14s15/
  • 1 month later...
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
