Gday Folks
Im trying to remove my flywheel bolts but with no luck. Im using a 19mm socket over them and originally tried to remove it with a repco breaker bar but to no avail.
So far Ive tried 2 different Rattle Guns and 2 different Compressors and had no luck what so ever. Ive hit the bolts with a hammer and still no go with the rattle guns.
Right now ive got my front pipe bolted to the flywheel (pressure plate bolts) so that the flywheel wont rotate (stuck against the chassis rail) and still it wont budge.
The car is only on ramps at the moment - do you think a metre long breaker bar would do the job if I got the car on a hoist?
Cheers,
JK
https://www.sau.com.au/forums/topic/127146-flywheel-bolts-wont-come-off/
Like above,
I've just done my flywheel, clutch (R33) on stands, got it of with a bit of force. I used a big torque ranch that you use to bolt up engines with and off she went... :(
Rattle guns are not always good. If your using a standard size ranch just put a pipe on it as big as you can find that fits under the car and you should be ok.
Cheers,
Alex.
Would be a lot easier on a hoist.. you can't get decent leverage with the car on ramps/axle stands.
I remember trying to change the pulsar's gearbox oil and I even jacked up the end of the ratchet until it was just twisting the engine on its mounts.. nothing. gave up and let the mech do it and it took him 3 big goes at it with a breaker bar to get it undone.
I ran into the same problem on a converted s14 engine recently. The japs must be mad for over tightening flywheel bolts. Combined with loctite they take can take a lot of leverage to crack. We managed to crack the bolt in the harmonic balancer before some of the bolts in the flywheel as we had the engine locked off that bolt originally :P
On the flip side, removal of the stock flywheel on my rb was a piece of cake with a short breaker bar and socket
yeah, sounds like they have been tightened to death.. as the torque on them is not stupid. I removed my old auto flywheel with just a standard breaker.
Tightening them too much can actually have the opposite effect, they stress, and can fracture. Fractured flywheel bolts can get very nasty. Don't over tighten when you do put it back on. The torque settings are in the service manual (that cannot be asked for.. )
J,
Did my flywheel recently - 3 bolts came off with the rattle gun, the others required a slug with the hammer first before the rattle gun worked.
I've found lots of stuff stupidly over-torqued on my car.
HTH,
Kot
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
