My wipers were bouncing about everywhere so thought I'd get some new ones. Tried some refills from Supercheap and they were crap. So took them back and got some of the Bosch wipers mentioned here (got from here in Adelaide as Supercheap didn't have them anymore).
And yeah, they're brilliant - literally cant even hear them move. They only make them for GTR's in R33, but these fit my GTS fine.
Edited by MrBurns
  • 3 months later...
anyone know STD wiper blade length on r32 gtr, same as r33 gtr size mentioned earlier
I have non STD ones currently but they are woeful
8905-9108
L=475?
R=500?
Very unsure.
Thats the assembly length
Edited by H4x
  • 3 years later...
I was changing my wipers on the weekend and I know this topic is a bit old but the info is still relevant so I thought I would share the blade sizes for some of our favorite Nissans in case anyone needs them:
180SX S13
Driver - 500mm (20")
Passenger - 500mm (20")
200SX S14/S15
350Z Z33
Passenger - 450mm (18")
370Z Z34
Driver - 525mm (21")
Passenger - 475mm (19")
Pulsar N14/15
Pulsar N16
Driver - 550mm (22")
Passenger - 400mm (16")
Skyline R32/R33/R34
Skyline R35
Skyline V35
Driver - 600mm (24")
Passenger - 425mm (17")
  • Like 2
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
