Hey,
I am looking at building an engine for a project over the coming months, and was wondering where in brisbane to send my rb20 block to be machined and bored? I know there is Headsense for porting and flowing the head, but the rest i havent been able to find.
If anyone knows of mahine shops who do this type of work can you let me know?
Cheers
Cameron
Edited by murrayis
https://www.sau.com.au/forums/topic/127183-workshop-info/
hey champ i can tell u not to go to *******, there prob not really what ur looking for but if u took a cheap option don't go there, i know of too many stuff ups on their behalf, sure the'll fix problems but not cover ur labour time.
EDIT: No public defaming of workshops, yes it sucks but that's the way it is - Revhead
https://www.sau.com.au/forums/topic/127183-workshop-info/#findComment-2352693
cost depends on how much u want done. you defintly want the bore machined to get the ridge removed, you can get the top surface of the block machined so its all the same height & better compression, you can get the crankshaft tunnels machined to fix twisting of the block but thats very x'y and i doubt youll notice the difference. I'm assuming your getting new cams so you dont have to worry about that but you can also get your crank machined to eliminate ovality and taper but if you can find a bigger crank maybe out of a rb30 or something along with longer and stronger con rods you wont get a longer stroke but youll get more mechanical advantage hence more power.
https://www.sau.com.au/forums/topic/127183-workshop-info/#findComment-2371073
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
