Hey guys,
I have changed my throttle body and i need to set up a tps for it.
I have an rb20 engine and have changed my throttle body to an xf one
I have noticed that the xf tps ranges from 500 ohms to 4600 omhs, but the rb20 tps ranges from 2000 ohms to 10 000 ohms.
Is there any way that i can modify the out put of the xf tps to turn it into that range?
Maybe using resistors or something?
Thanks for any help
https://www.sau.com.au/forums/topic/127208-any-electronic-gurus-in-here/
Nah no aftermarket computer
I don't have the rb20 tps any more, it got sent out in the rubbish thanks to my brother
I have put power through the tps.
The idle voltage is 1.85 V and the fully open voltage is around 10 V
Is there anyway of changing it at all?
Like something where you can set the starting resistance at .5 V and set the end at 4V and it controls the in between from this information?
Thanks for any help
Not real sure on nissan computer signals but I think the computer will be monitoring the voltages and not the resistance.
Sounds like Xf TPS = 0 - 10 volt and Nissan = 0 - 5 Volt absolute readings.
Both are industry standard signals and you can get simple convertors for the task of scaling these voltages, even a 0 - 5V convertor will easily be adjusted to give you 0 - 4V if that's what you really need...
If your even a little handy with a soldering Iron I think you can buy a build it yourself kit from Jaycar or similar prolly from around $30...
Hope this helps.
Edited by Redsw20T
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
