Hey guys,
I have changed my throttle body and i need to set up a tps for it.
I have an rb20 engine and have changed my throttle body to an xf one
I have noticed that the xf tps ranges from 500 ohms to 4600 omhs, but the rb20 tps ranges from 2000 ohms to 10 000 ohms.
Is there any way that i can modify the out put of the xf tps to turn it into that range?
Maybe using resistors or something?
Thanks for any help
https://www.sau.com.au/forums/topic/127208-any-electronic-gurus-in-here/
Nah no aftermarket computer
I don't have the rb20 tps any more, it got sent out in the rubbish thanks to my brother
I have put power through the tps.
The idle voltage is 1.85 V and the fully open voltage is around 10 V
Is there anyway of changing it at all?
Like something where you can set the starting resistance at .5 V and set the end at 4V and it controls the in between from this information?
Thanks for any help
Not real sure on nissan computer signals but I think the computer will be monitoring the voltages and not the resistance.
Sounds like Xf TPS = 0 - 10 volt and Nissan = 0 - 5 Volt absolute readings.
Both are industry standard signals and you can get simple convertors for the task of scaling these voltages, even a 0 - 5V convertor will easily be adjusted to give you 0 - 4V if that's what you really need...
If your even a little handy with a soldering Iron I think you can buy a build it yourself kit from Jaycar or similar prolly from around $30...
Hope this helps.
Edited by Redsw20T
