So far the injury has been plagueing me for 3 years. It took 2 years for the first surgery to be allowed. I had 6 weeks recovery after the first surgery before starting some light gardening and the disc ruptured again. Significantly I didn't have the caurterizing in the first. The surgeon said I was fine and could start heavier activity. Good neurosurgeon but this time I have one of the best orthos around who does just backs and I trust his judgement.
This time definitely 6 weeks of light walking then a slow increase. Army will keep me in a bit longer until I'm fit to discharge. I was retiring 31 Aug.
Obviously no DECA, but I have the opportunity for a full life without disability so the trade is worth it. I may or may not make Meridians day. I'll see if Spence will take me.
Chris, feel free to drop by. I'm good for making a decent coffee. 0408 1254 767.
Shame about DECA Geoff, surely someone could drive you up to partake in the usual evening events though :(
Take it even easier now mate and look forward to seeing you back out and about in team purple. :(
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
