Have had huge issues with my RB20det lately, probs are, ignition cutting out at various points in the rev range (not a miss fire like a plug or coilpack would do, but rather a total ignition cut of all 6 cylns) Some times the problem is only while drifting through corners and not in a straight line.. but a couple of times it has happened while on fullboost in 3-4th gear in a straight line and the ignition will cut out, come back, cut out quite repetively.
Now while this is happening, the Tacho also dies... so to me it indicates a loose wire, or a problem somewhere in the wiring of the ignition system. This resulted in me pulling my loom out.. have a look at it and tell me if all the electrical taping in black is factory or not? I know the red tape looks to be non factory...
https://www.sau.com.au/forums/topic/127226-rb20det-loom-help/
Nissan does some funny stuff with its wiring, and I believe it is hand wrapped. Some of the black tape looks like a home job, but it's actually factory. Mine was the same. Red is probably extras somebody else has added on.
It could be a CAS problem? A few have had that problem on rb20det's. I think the ECU determines the RPM / Tacho signal from the CAS as well.
i had a issue like this, it would drive fine, then it would start cutting out. it did not matter if you were in a high or low gear, some times i could rev it to 7k and it would be fine, then other times it would just cust out.
i replaced the o2 sensor and it has been fine ever since.
To test if its the o2 sensor.. remove the o2 sensor plug. Car will work fine without it. Just won't run in closed loop mode, and you'll use more petrol.
Its something like the o2 sensor immitantly sends faulty signals the ecu has problems. But if you remove it totally you can isolate the problem a bit more closely.
I'm not sure how you test the CAS, you'd need to monitor the voltage signals, or use the consult connector to see what's going on.
Also when it does fail, stop the car, and put the ecu in fault mode, and it should flash the sequence for the last thing that failed.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
