Have had huge issues with my RB20det lately, probs are, ignition cutting out at various points in the rev range (not a miss fire like a plug or coilpack would do, but rather a total ignition cut of all 6 cylns) Some times the problem is only while drifting through corners and not in a straight line.. but a couple of times it has happened while on fullboost in 3-4th gear in a straight line and the ignition will cut out, come back, cut out quite repetively.
Now while this is happening, the Tacho also dies... so to me it indicates a loose wire, or a problem somewhere in the wiring of the ignition system. This resulted in me pulling my loom out.. have a look at it and tell me if all the electrical taping in black is factory or not? I know the red tape looks to be non factory...
https://www.sau.com.au/forums/topic/127226-rb20det-loom-help/
Nissan does some funny stuff with its wiring, and I believe it is hand wrapped. Some of the black tape looks like a home job, but it's actually factory. Mine was the same. Red is probably extras somebody else has added on.
It could be a CAS problem? A few have had that problem on rb20det's. I think the ECU determines the RPM / Tacho signal from the CAS as well.
i had a issue like this, it would drive fine, then it would start cutting out. it did not matter if you were in a high or low gear, some times i could rev it to 7k and it would be fine, then other times it would just cust out.
i replaced the o2 sensor and it has been fine ever since.
To test if its the o2 sensor.. remove the o2 sensor plug. Car will work fine without it. Just won't run in closed loop mode, and you'll use more petrol.
Its something like the o2 sensor immitantly sends faulty signals the ecu has problems. But if you remove it totally you can isolate the problem a bit more closely.
I'm not sure how you test the CAS, you'd need to monitor the voltage signals, or use the consult connector to see what's going on.
Also when it does fail, stop the car, and put the ecu in fault mode, and it should flash the sequence for the last thing that failed.
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
