Hey guys,
just out of the blue my interior light in my car has deicided to turn on even if the doors are closed and the car is locked??
also, i turned on my head lights, and my front right one didnt work, so i turned them off then back on and then the front left one didnt work, so i turned them off and on again and now they BOTH work.
but the interior light still stays on even when the doors are closed and locked.
if i move the light to "OFF" then yeah it stays off, but if its in the middle position, where usualy if you open a door it turns on, it just stays on all the time.
its really annoying me, i cant think of what it might be!
the only thing electrical ive done lately is install a sub and amp, but they have been working fine for 2 weeks.
A while ago a mouse somehow got into our lockup garage and chewed a whole bunch of the wires in my sister brand new astra, boy was she pissed.
im really hoping thats now what has happened here.
https://www.sau.com.au/forums/topic/127275-weird-elextrical-problem/
when i open a door and push the little button thing that should turn the light off, nothing happens, neither the drivers or passenger button makes the light turn off, which leads me to think that something is shorting out somewhere, but thats the problem... SOMEWHERE!
i have been looking under my dash at the wires and nothing appears to be out of place, god only knows, i was doing some work in the engine bay, i may have knocked something loose in there?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
