I assume you don't know anyone in Italy ?
Marranello, I think would be pretty hard too get too. Its a basically a very small town based around a race track and the Ferrari Factory and Shops, Museum.
There would have too be transport from Milan or Veronia. Very much worth it.
It is seriously in the middle of no where. One main street. Try and get there around midday, or knock off time, its worth too see all the mechanics in their unforms going home.
If your lucky you might see something running around the track.
https://www.sau.com.au/forums/topic/127299-going-to-italy/#findComment-2350786
When I was in italy I went to Maranello and went to the Museum.
Its pretty cool and all the cars there are not donated by Ferarri, but bought by the museum itself.
It has heaps of new and old cars, heaps of the F1 engines and also heaps of cut aways.
Its pretty cool and worth the while if you are in the area, but i wouldnt make a special trip.
I am not sure if you can go to the "factory" itself. As for getting there, we were in a car so we drove so i cant give any directions or anything, sorry bud.
https://www.sau.com.au/forums/topic/127299-going-to-italy/#findComment-2350872
yep I went in 2001 worth going to galleria ferrari tasty race F40's and the like.......
I think Bologna is the closest big city, I got a train from there to Modena and then a bus out to Maranello which is Ferrari town lol merchandise everywhere
if ur lucky like I was u may also catch them testing on the Ferrari circuit saw the then F1 car do laps was awesome
not sure about the actual factory though might need to be more official and booked but give it a go
https://www.sau.com.au/forums/topic/127299-going-to-italy/#findComment-2351486
You can get buses that will connect to maranello from bologna, verona or even Milan or Venice. You will have to connect with more than one bus so take special notes of the bus times especially when returning at night to often over there I got caught out because the last bus left a particualr station at 10.30pm and my bus arrived there at 10.45 and this was the last bus of the night!!! Do you speak Italian? If not try to get it all organised days in advance as just rocking up the day to the station etc could make it really hard for you.
The ferrari museum is ok, just near here is also the Lambo factory which is really cool, and also in the area is maseratti and the ducatii factory
https://www.sau.com.au/forums/topic/127299-going-to-italy/#findComment-2351501
You won't be able to get a tour of the actual factory.
Bus transport from Modena is fairly easy if you are polite with the people at the information desks :(
The museum, shops etc. are worth the visit if you are a bonafied Ferrari freak. The atmosphere is awesome... but to be honest with you I think visiting the Alfa Romeo museum would be a better payoff. Unless, of course, you have time to visit them all!!!
https://www.sau.com.au/forums/topic/127299-going-to-italy/#findComment-2352439
Thanks guys for the replies :)
I've sort of figured out the 2 buses to get to maranello....
title was a bit misleading - you have to have a fezza to actually get a tour of the factory - i don't think a GTR will cut it, unfortunately.
Will still check out the museum on the way through to venice from rome!
cheers
https://www.sau.com.au/forums/topic/127299-going-to-italy/#findComment-2353842
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
