I have just had my VG30DETT rebuilt and have added Sard 650 injectors.
Originally used stock 320's and on the dyno it made 268.5 @ 16psi with a good fuel map.
Now I need to change the fuel (flow?) % , as the sards are close to twice the size,
so I can get it to the tuners, about 30km's.
I use a Microtech LTX12 with the in-car dash display and I was wondering if
anyone has experience with these ecu's and/or can offer some advise.
Cheers. :(
Cheers. :P
You can take a global percentage out, its called the Mix trim. Because they are twice as big doesn't mean they flow twice as much at low pulse widths so just take out 30% and see how you go. You might struggle with those injectors using a microtech economy wise.
Thanks guys for the heads up.
Satanic, these are side feeds and high imp, I think yours would be top feeders and low imp.
don't forget to get the lag time figure for them too.
Richard, WTF is the lag time? :)
lag time/latencey/response time is meaured in mili seconds. different injectors have a different lag time. you need to find out what stock is, and what the sards are. or in your case you may just need the figures for the sards. it's important that they have the correct lag time inputted into the ecu to run properly.
Microtech doesn't have a lag time adjustment, you just tune it in milliseconds
cheers. so does that mean you just tune and compensate for it, or do you just need to enter in the lag time figure for the injectors you are using?
Thanks Beer Baron and Adriano, I think I get it, I'll speak to Boosted Zed.
Adrian, the Sards cost me $660 delivered through Greenline and
the collars were $120 for the set including o-rings and hex bolts in
a G/B on aus300zx forum. :D
