After 4 years, checking if anyone has started/kept playing this.
I still do on a fairly regular basis.
If you do, let me know and I will add you to my friends list.
Yes, I've been thinking about how to fabricate something. Either how OP did it with an alloy sheet or more complicated. Because of the CD shifter protrusion I think I will need to build a raised aluminum box to clear, then I would reutilize the same OE seal just shifted back. When I went on my test drive I popped open the EWG and exhaust just filled the cabin, so it will need to be closed up.
Car is struggling to rev from idle when you accelerate normally to spirited, But it will get past 1000ish rpm if you feather it, and then is fine so long as the revs don’t drop again. Idles fine. Plugs come out wet as after a few min.
Things changed are:
CAS, ARM and fuel reg from a engine that was confirmed working 2 years ago
Injectors have been reconditioned
ECU has no codes
Where to from here?
Video of the issue can be seen here
