Now thats gold, pure gold, Im going to start recording this stuff!
They've been around for a while now, before the "war on everything" they were "CNNNN Chaser cable" if you're looking for old vids etc
They started off as a uni magazine doing satirical news (at USYD, I think), which is where most satirical news started.
They still update their site:
http://www.chaser.com.au/
which has some gems.
As a former wanker number plate owner i though this was piss funny.
From 'The Chasers War on Everything', ABC Friday afternoons.
Hey is the link still up?
I've gotta see this one. Love their show.
Does anyone where to get their full episodes from?
You can get them if you use bittorrent. Torrentspy.com has them all on there, most of them anyway.
I get them from http://aussietorrents.com
Episode 23 just aired and 30 minutes later its available... :)
Hey I checked it out on torrentspy.
Couldn't find anything except one that aired on the 24th on March
http://www.torrentspy.com/search.asp?h=&am...the+chasers+war
The people capping the episode are all on aussietorrents. You will find them all there.
http://aussietorrents.com/vb/showthread.php?t=3603
10+ seeds for all 23 episodes.
Edited by Kero
http://www.torrentspy.com/search.asp?h=3A3...&submit.y=0
or aussietorrents like Kero said, I think that's where the torrentspy site gets them from anyway.
Edited by Lithius
aussietorrents dont host the torrents... Its just an Aussie forum that the rippers post links on. The torrent downloads are on Demonoid and mininova (and others).
Its by far the best place to find australian tv rips.
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
