http://www.nissanperformancemag.com/october02/skyline/
Hey guys,
i stumbled across an old article about a r32 GTR that supposodely runs 11.5 down the quater with the following modifications
Standard Garrett T28 Turbos
HKS Cam Gears
Trust Airinx Filter Kit
Custom Bleed Valve
Standard Dump Pipes
Trust MX Front Pipes (75mm into single 80mm)
Click for Full Image Straight through Cat Converter
HKS Hiper Cat Back Exhaust
Exxedy Single Plate Three Puck Clutch
producing a Best of 240rwkw
Is it just me or does this list of mods and power output seem like it wouldnt be enough to crack a mid 11?
Just asking out of interest...
Daniel
https://www.sau.com.au/forums/topic/127411-11-second-gtr/
I knew this car well as it belonged to a fellow FangArtist (HiRisk).
Absolute animal of a car for the minor mods it had.
To put it plainly, Shaun drove it like he stole it in those runs. This included rev limiter launches, flat shifting and doing everything humanly possible to pull the fastest possible time.
https://www.sau.com.au/forums/topic/127411-11-second-gtr/#findComment-2353961
As Leewah said ............. the car made 253rwkw on Racepace dyno ............... which one of the 1st cars at Racepace to make over 250rwkw with stock turbos. When the car was raced 1/4 mile it had no rear spoiler, spare wheel or anything in the boot. Shaun also would switch the car to rwd mode for a big burnout on old semi-comp tyres. It was great car and owner knew how to drive it hard, the car visited 9000 rpm a few times. :laugh: "Hirisk" always knew how to put on a good show :)
https://www.sau.com.au/forums/topic/127411-11-second-gtr/#findComment-2354230
Car was in perfect condition when he sold it.
It just goes to show that you can absolutely thrash the hell outta a car but as long as it's properly maintained, there really shouldn't be any issues with it.
Those were the good ol days when we could cruise/fang where we liked and nobody asked any questions. Nowadays, you'd be nuts to go out and do half of what we used to do.
FangArtists FTW!!!
Hey cheers for the responses guys ... im suprised to see that a couple of you guys actually know him. He must have thrashed that car hard did it need a rebuild by the time he was finished with it?
https://www.sau.com.au/forums/topic/127411-11-second-gtr/#findComment-2356238
Thats about the quickest time ive seen for stock turbo's....
Ive heard of a few NZ boys cracking mid 11s with stock turbo's, anything under 11.99sec is very good IMO.
Ive seen a R33 GTR with hi-flowed stockies make 280RWKW and run 11.70 @ 117MPH. I thought that was pretty impressive.
I also know of a R32GTR with R34 N1's that ran 11.20....
https://www.sau.com.au/forums/topic/127411-11-second-gtr/#findComment-2357247
shudup :wave:
It was my 3rd run of 4 and first time at the drags. I'd never even practiced launching before :)
dial in limiter, drop clutch, hang on = fast :wave:
There is also a 32R thats dipped into the 10's with R34 N1's, although not street fuels :D
https://www.sau.com.au/forums/topic/127411-11-second-gtr/#findComment-2357956
As Leeway and RPMZ have already mentioned, this was HiRisk's car.
The car did do that time with listed mods but driven very hard/well with semi comp rear tyres.
FangArtists FTW!!!
The good ol days....never to return...
https://www.sau.com.au/forums/topic/127411-11-second-gtr/#findComment-2358308
    • You would probably do a lot better in a claims process then most people. When I called the insurance company, they were surprised I read the pds because according to them almost no one does lol.
    • Yeah it should be, but I wouldn't be surprised if the insurance company tries to pull some argument out of their ass to avoid paying you out.
    • On some cars like MR2 Turbos they're notorious for not letting the wastegate open far enough to avoid overboost, especially certain cheap downpipes. If adjusting "percentage cycle" fixes it then it's just an electronic control issue, not a hardware one.
    • Same.  It's depressing to say this but the skyline can go months on the charger between drives.
    • I often leave mine connected weeks at a time. The main one I use is the old model of this, it has 2 important features - choose battery chemistry other than lead acid (most of mine are AGM) - power supply mode which you can use to try and recover dead flat batteries as "smart" chargers often don't recognise a dead flat battery is connected https://www.projecta.com.au/products/IC10/intellicharge-10a-bat-chgr The Ctek I  use was meant to have a battery test mode as well but it doesn't work 100% of the time so I am pissed at them. The distributor did everything possible to make warranty and support difficult so I'll stay away in future. The main thing with a "trickle" charger is it has multi stage programs, ie once the battery is full it turns the current right down to just maintain the charge....in the old days we just used real "trickle" chargers for that which had a maximum output of say 500mA which was safe to just leave connected to dumb old lead batteries.
