Hi people
I just brought a R33 GTS
and almost every time i tromp it in 1st i hit the limiter b4 i go to second gear. Also the other day it was raining and i took off hard it span 1st to the limiter just b4 i could change gears.
Im not holding it on the limiter its just hiting it like "pop,pop" and then i change, and i goin to do any damage to my engine or is that what its there for???
Do you guys ever hit the limiter or are you all changing at like 6g???
just need some reasurance i dont wannner blow anything up
thanks
Deano
https://www.sau.com.au/forums/topic/127417-rev-limiter-should-i-use-it/
i hit mine in second a few times when i first got it, but u quickly get used to changing before redline.
i reckon it's because the rb's dont feel like they're struggling, even at high rpms, so it's easy to over rev.
keep an eye on ur tacho when ur gunning it.
i would hate to buy your car after you have given it as hard a time as you are... i have like to have fun in my car which i have owned for almost 2 years and i think i have only hit the rev limiter maybe 4 or 5 times in that time
Man, some DAYS I hit the limiter 4-5 times.....and thats in an AUTO
My RB's never missed a beat, give it good oil and genuine everything else.
I dont think its a matter of not wanting to buy his car, rather, someone really wanting to buy yours :O
touching the limiter occasionally shouldn't hurt the car. bouncing off it is bad, because your engine's cycling from 0% to 100% power rapidly.
most cars reach their power peak before redline, so you're wasting your time trying to get that last 300rpm out of the motor. my charade was different, torque curve completely flat to the 7500 limiter so I may have hit it a few times during its lifetime :)
I never try to get to the limiter on first - second i ahve hit a few times. These days though, i take it max maybe 5 (eg when im on the fwy ramp) - no point in hurting the car, unless you are a rich punk who can afford to kill off a few skylines :)
agreed... if you can't tell when you're getting close to redline, and you hit redline every time you take off in first, you're obviously too unco-ordinated to be driving a high performance car... no.. wait... make that driving fullstop...
do everyone a favour and either learn how to drive properly, or sell the car and start catching a bus, otherwise we are going to hear about another skyline written off on the news.
c'mon guys ease up a tad. he is just asking if it's bad for the car or not. personally i would suggest it's not a good idea. a non-turbo skyline has seen it's best power wise a long way before the limiter anyway so really not much point. you will get a feel for the revs etc as you get used to driving it so wont hit the limiter so much after a while.
Put it this way, if everytime u drive it in every gear ur hitting the limiter then eventually something will f()ck up. Once or twice here or there wont do nething. Trust me tho after a few weeks u'll be able to change in time. Practice makes perfect
You also shouldnt be driving then :) although an auto should change before it hits the rev limiter anyways shouldnt it ??? As others have said i had mine on a dyno and from memory peak power is like 6400rpm so why take it to the 7,000 rpm or 7,200 whatever it is...
A: my car is not for sale
B: if it was i would by my skyline if i was looking :D
I dont think its a matter of not wanting to buy his car, rather, someone really wanting to buy yours :(
BeeR Rev Limiter really good cuts ignition as oppossed to your factory rev limiter cutting fuel which can cause damage...they also sound cool and make some nice flames!
sure, as if skyline turbos arn't weak enough...
how does a fuel & ignition cur cause damage, where an ignition cut doesn't? Ignoring the damage to the turbo / exhaust that a misfire system inevitibley causes...
Why rev it to redline? you go quicker if 1) you have traction and 2) (average)engine power - which probably drops off in the high rpm.
Driving like that will cause damage - if not to your car, then to some one elses.
As long as there is good oil (and the engine is warm), I don't see it causing any immediate engine damage - but it sure causes alot more wear % tear (and not just the engine). Buy some good tyres. better traction, AND you won't want to waste them.
now you really are showing your smarts... I never encouraged driving on the limiter. and if you read my post that you saw fit to quote you would see I suggested that in a non-turbo skyline peak power would occur long before the rev limit (as it does in turbo versions too). i dont think it's very wise to tell me to buy better tyres. what tyres are you using on your car? have you even driven a tuned GTR with 260kw atw? in rwd? in the wet? I can tell you it's pretty angry when it ramps onto boost. or are you just advising me based on your experience in gran turismo? in fact it's hard to believe you were responding to my post at all. when I said:
"personally i would suggest it's not a good idea. a non-turbo skyline has seen it's best power wise a long way before the limiter anyway so really not much point. you will get a feel for the revs etc as you get used to driving it so wont hit the limiter so much after a while."
but thanks for your valuable advice.
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
