Hicas is your cars four wheel steer, check the power steering and hicas fluid levels mate.
thanks champ just wondering if u know where the hicas fluid is located in the engine bay? Cause my mechanic checked everything today said everything was right level must of missed it? or he has know idea what hes doing didnt know what the light was.
https://www.sau.com.au/forums/topic/127428-hicas-light/#findComment-2353035
R33 skyline is electric - i.e. no fluid required. It has an elecric motor.
Mine does that aswell. I am turfing it -
It could be a sensor trouble - sothing wrong with the rack or it needs to be reset and aligned at time of wheel algnment.
I am replacing mine with a bar.
Geoff on here sells them for $150..
https://www.sau.com.au/forums/topic/127428-hicas-light/#findComment-2357206
my r33 had the same problem, and all it was, was it needed a small amount of powersteering fluid.... so im not sute who is right !! but im still sure they all have fluid int he engin bay .... might only need a touch of fluid thou !! very toutch system
Had the same issue and did the same thing and it worked :angry:
https://www.sau.com.au/forums/topic/127428-hicas-light/#findComment-2360540
    • Hi all. So I have my GTR on the lift and have been working on it a few days and today I unpacked the frontpipe that was wrapped with heat wrap stuff, because part of it was breaking down and soaked in oil. Noticed that the pipe itself does not actually look like a Mines, despite it supposedly being a Mines. But I could not find any fronpipe online that looks exacly like his, and I don't think it is a custom one. My amateur measurement also showed the two pipes are about equal length, so maybe this is just an old version of the Mines pipe? Would appreciate insight on this by the enlightened folks. greetings from Germany
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
