A few months ago i got my car tuned to 11 psi and got 205rwkw with an af/r of ~11. Now on a little more boost the car doesnt go at all like it has fuel cut out and the engine just jerks when it cuts out. I had my timing advanced and i have been told the standard ecu resets itsself when it exceeds 205rwkw. I am assuming my timing has gone back to zero. Under load on high boost it misses alot. Hits full boost approx 13 - 14psi at 3 - 4,000 rpm and after that it feels like nothing. just slow revving to 7,000 rpm.
If anyone can shed some light on this, it will be greatly appreciated.
Thanks, Phill [LTHLRB]
Edited by LTHLRB
https://www.sau.com.au/forums/topic/127452-tuning-out-of-wack/
do you have a remap?
if YES
the ecu could be picking up excessive detonation and dropping to the low octane map
was the rich and retard protection removed/disabled/edit'ed to go away?
if NO
rich and retard is being activated due to the ecu seeing excessive airflow, ie: more than it is happy with dealing with, so it panics and protects itself, dumps the timing and richens itself up. a search will give you the answers you are looking for
it wasnt remapped. It was going fine for a while and i ran a 13.1 second pass at calder in full street trim. But after that it just died out. I think its retarding and getting very rich. Fuel economy is out the window. Engine isnt pinging or knocking though. Fuel delivery is fine. 500hp tomei pump is doing well. The car is going in tomorow to get tuned. Is there any way to remap the standard ecu's ?
well the dyno tuner is going to run through the afr's. Also re gap the plugs. Also get the right boost and check for pinging/knocking. Also advance timing to a safe but good level. Not much really you can do to a standard ecu. I just want it to last till nov/dec when i get my power fc :O
  • 4 weeks later...
like paulr33 said, too much boost made it dump the timing and richen itself up. The plugs were re gapped and pinging and knocking was checked. Ignition timing was advanced to a safe level. Made more power than last time on 11psi. Cant go much more than that or it will do the same thing over again.
out of interest how far did they advance the timing? i know stock is 15degrees advanced at 650rpm? is 20degrees advanced at 650rpm doable?
    • Stock RB fuel pressure is near enough 43.5 psi, so the latency in that table at 31.6 will be close. You can see that 7 or 8 psi equates to about 0.4µs extra latency. So if you wanted to interpolate between the 31.6 and 39.9 psi values you could say you're going up about 2 psi out of those 8, so add about 0.1µs, which is barely worth talking about and is quite possibly wrong because ideally you would fix the latency while running at the appropriate conditions on the dyno, with a wideband sniffing its butt.
    • The pressure, is what you set the fuel pressure to. If you have the factory fuel reg, you'll need to find the factory spec. I don't know it off the top of my head, but someone else might.
    • For others, what GTSBoy states here should be paid attention. Why? Well lots of people play with different engines, and they LOVE to change things like remove AC, or steering pumps etc, and it lends to them needing to move the tensioner too. You want your tensioner, particularly those that are sprung or hydraulically tensioned, to be the first thing after the harmonic balancer, or technically the "last" pulley in the chain. By saying last pulley, I mean look at the direction the crank spins when the engine is running, follow the belt from where the crank is pulling the belt FROM, and keep following that until you're between the last pulley/accessory on the belt and about to reach the crank again, this is the spot where you put the tensioner. This is the area that will always end up with slack. This is worked out exactly the same way for chains too, as the physics is the same for them. The crank pulley is where all the force to drag the belt around comes from. You will never ever get rid of the slack that appears, especially under load. The tensioners job is to keep the belt loose enough when stationary that there shouldn't be out of sync movement in slow movement, and then be tight enough when running, that the belt can't jump off any gear and get damaged. Too tight, bad things happen, too loose, bad things happen. Have a tensioner (mainly sprung/hydraulic one) in the wrong spot, it can't actually do anything about keeping the tension.
    • It was gonna take much longer for the 440cc so I'd thought I'd risk it with the 550cc. They finally arrived and I couldn't wait any longer (I could but I was quite excited after 2 months) and installed them myself. Removed the old injectors, inserted the new and connected everything up. Before starting the car, I tuned the injector size from the factory 270cc to 550cc using Nistune.   This did some of the calculations automatically which catered for the TIM. The latency however did not seem to change. Deatschwerks have the tuning data available for each injector online, and I had a look at it. It has a table which relates to latency according to pressure and voltage (see below image). Nistune requires the 14v value, but I am unsure of which pressure value to look at (my lack of knowledge and experience have something to do with this). The highlighted value is close to my current latency which is 760µs. It is for 14v which makes sense, and the pressure is 31.6 Psi.   I still gave the car a test drive to see how it goes, and honestly it has never felt so powerful before (and some people say the RB20DE is very weak?). I really enjoyed the drive. Side note; The injectors are quite noisy, which someone mentioned before. This does not really bother me however. I will still ask my mechanic to have a look at it and perhaps ask a tuner to fine tune it if they have the knowledge.
    • Also true. But imagine not wanting new injectors? Imagine wanting to use 30 year old injectors?
