hi guys,
im driving an 89 r32 gtst which is fairly stock with the following mods:
greddy cat back exhaust
k&n air filter
ms air flow meter
stock boost ( tried running the car at 12psi, but didnt feel much difference except for the lag?)
the problem with car is when i floor it, it doesnt really seem to go :(
the accelerator pedal doesnt seem to be very responsive at all
like it will go and you can slightly feel the boost
but you wont feel the rush as much as say a 180 or a wrx :)
the car also lacks low end response
i know its a 17 yr old car and heard its very common amongst r32s
but would you guys recommend any mods to fix this?
or could it be a problem with the car itself?
any help would be much appreciated
thanks ;)
https://www.sau.com.au/forums/topic/127461-need-some-help-with-r32-rb20det/
My r32 was quite laggy when it was stock.
It didn't really improve with a fmic and 3" catback but I got improvement once on full boost.
My car is a manual but my son bought a stock auto r32 and it was much less laggy.
I thought it must be the gearing or torque convertor but when we converted it to manual it was still less laggy.
I think it is because the auto ecu is programmed to run 20 degrees initial advance where the manual is programmed for 15 degrees.
You can't just advance the manual to 20 degrees because you will be running 5 degrees too much advance when you come on boost.
I suppose we should have swapped ecus to find out but I'm building a 2.6L rb25 and running a pfc now.
i had a problem with my 33 when i put a dual stage boost controller on it. when i changed gears the air between the wastegate and the contoller wasn't realeasing so when i grabbed the next gear the wastegate was still wide open and it wouldn't boost. put my old turbotech controller on and it goes fine. i also have a mate with a turbosmart boost tee that does the same thing.
so a cause of it may be a sticky wastegate, or for the people with boost controllers, it might be the controller.
I believe the problem is lack of stroke/bore.
Try a rb30det :D
I guarentee it will put a smile on your dial! Im smiling :D
Ok sorry...on a more serious note, rb20dets dont understand the word torque, but they understand revs. They are a very peaky motor, you need to rev the shit outta them to make power or punch. With the sort of mods you have everything seems abit restricted...free up the exhaust, you will find it opens up abit better down low and midrange and try an intercooler that might actually drop the intake charge air temp. If everything else fails...revert to my original suggestion.
Edited by r33_racer
It's all relative.
5 degrees more advance will help but an rb20 is always going to be sluggish off boost
The main reason an rb20 is laggier than an sr20 is because it has such a short stroke.
Is your M's afm 100% compatible the the stock ecu?
Maybe a remap would help.
Just a suggestion, get in the passenger seat of it and go for a run. I got so used to mine that i posted in here a while ago trying to figure out what it was. Dyno'd it @ 135kw, which sounded okay, so got my mate to take me for a spin. Scared the crap outta me, feels a helluva lot faster when your not the driver :(
lol first of all thx guys for ur replies :(
from your replies im looking at:
chucking the car on dyno.
adjustable cam gears - exhaust and inlet
dump/front pipe
ecu remap
and ask a friend to drive it for me
lack of stroke/bore? is there anyway to improve this without changing the engine?
so should i do all of the above??
man looks like im gota save up for a while...juz paid off my insurance :(
again thx for the help guys
lol s2k12 i woulda got a gtr but im only on my Ps bro :)
p.s guys how much kms u guys getting from ur car??
ive noticed my cars got very bad economy :laugh:
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
