I dont believe bhp = rwhp
brake horsepower is power measured at the flywheel as on an engine dyno
and rear wheel horsepower is that figure less any drivetrain losses.
So dirt garage made about 540hp at the wheels(4) on that setup.
Edited by r33_racer
https://www.sau.com.au/forums/topic/127478-700cc-injectors/#findComment-2354518
thats just outright horsepower as in hp...i was always of the understanding that bhp was at the wheels i.e. the brakes.
we also made between 443 and 467 on the same setup using race fuel.....depending on the day/dyno/boost levels.
https://www.sau.com.au/forums/topic/127478-700cc-injectors/#findComment-2354724
A general rule of thumb for (manual) drivetrain loss for newish cars is:
AWD 18%
RWD 14%
FWD 12%
So for RWD -
Given that 700cc~700hp
700hp - 14% = 602rwhp (~449rwkw)
No...
drive train loss is NOT A PERCENTAGE
its a pretty much fixed figure, give or take a hp due to oils/wear..
real loss figures are like this
AWD, it varies system to system, i believe the atessa setup sucks about 70hp out of it
RWD, 25-30hp
FWD 30-40hp
add to it you will lose more power if your driving an auto, but its about 10-20hp extra..
% loss figures are utter crap, and not to be believed, if your going to quote a %, use a sliding scale for loss compared to power, do not just have a flat % value as your loss, as its totally and utterly wrong..
Edited by Denver
https://www.sau.com.au/forums/topic/127478-700cc-injectors/#findComment-2354896
No...
RWD, 25-30hp
FWD 30-40hp
I realise the percentage calculations method is flawed but, its a quick way to get a good guesstimate.
BTW RWD has slightly more of a drivetrain loss than FWD.
https://www.sau.com.au/forums/topic/127478-700cc-injectors/#findComment-2355227
No...
Well thats not correct either
https://www.sau.com.au/forums/topic/127478-700cc-injectors/#findComment-2355257
no, brake horsepower is the measure of the power without any ancilarries (no alternator, no gearbox, no air con etc etc). it doesn't have anything to do with the brakes :rofl:
cool...i can go home now....ive learnt something.
https://www.sau.com.au/forums/topic/127478-700cc-injectors/#findComment-2355262
yeah i'm a fountain of knowledge... well i'm a fountain of something. lol
i think SAE measured HP is done with all ancillaries for the car it is to be installed into and power is measured as what is being delilvered to the flywheel. it's more common now than BHP.
https://www.sau.com.au/forums/topic/127478-700cc-injectors/#findComment-2355384
    • yeah, there's a country that recently started importing Skylines, I blame them.
