  • Replies 56
Well from my experience they check the rego sticker for car information?
Also - can anyone else confirm that rego stickers for S2 skylines are 1600KG? (I presume they are all the same?).
i dont think you're going to get off on the rego sticker....as far as cops are concerned, R33 GTS-T's are over the power to weight limit (and they're correct)
But it would help with the argument that the car is 'legal', especially if the officer isn't 100% certain. Would help even more if you had a GTS rego sticker, just say "errmm no, my car is a GTS not a GTST" :(
You have an S2 don't you? Able to quickly check? :(
Edited by ReeceR
yeah i could check, but i really do not see the point
you're saying you want to register your car as something its not, to beat a possible $100 fine...
if you dont want to take the risk, get an R32
Well if the car's registration actually says that it is 1600KG, and the S2 Skyline on stock specs makes it possible for a P plater to drive, doesn't that mean the car perfectly legal?
Just because GTST's aren't legal, doesn't mean that all variations are illegal too. I think if your rego sticker stated the weight of the car was fine for the power to weight ratio, the coppers would feel a little un easy giving you a fine.
well i think its obvious the sticker is wrong...and given the fact that its well known ALL R33 GTS-T's are over the limit
my cousins VX clubsport has about 1250kg on the rego sticker....and i think we know thats a very ambitious figure....
It's a good point... If the sticker said it's a GTS, then they surely couldn't fine me for driving a GTST? (Even if it is, how would they be 100% sure).
Who knows. Some cops are assholes I guess.
EDIT - Yeah, I'll just take my chances. See millions of skylines with P plates up, hopefully I can just fit into the crowd... :(
Edited by ReeceR
its like beating my head against a wall..
I'll put it as simply as possible.
ALL R33 GTS-T's are OVER the power to weight limit. If you are on your P's in Victoria, and are caught driving one, the cop has every right to fine you for doing so. There is NO WAY to beat the rule.
If you want to attempt to register your car as a GTS, then by all means go for your life...just be sure to tell vic roads that the engine number is wrong, and then be ready to answer the barrage of questions that follows....
lol...
Relax, it was just an idea that came to mind. You said it's not possible/etc. I believe you. I probably wouldn't have tried even if there was a high chance of it been possible.
As I said, I'll just take my chances. A lot of others seem to get away with it, so hopefully I can too.
lol...
thats more like it
I'm a p plater. my car is over the power to weight ratio (by SFA but its still over). I knowingly break that particular law, everytime i drive my car.
If i happen to get done for it, then so be it. I will not argue with it whatsoever as its pointless, and will lead to the officer getting me for everything else under the sun as well.
Im yet to be pulled over in my car....however, drive like an idiot will give them more reason than they already have to pull you over, and then it'll be time to bend over.
You're probably one of the first P plater skyline drivers I have heard of who hasn't been pulled over.
Hopefully they don't get you either.
Guess it depends on what area you're from, how you drive and just how lucky you are really...
Guest
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
