Hi I have
R32 Clutch and Brake pedal for manual r32.
if anyone needs them for 5spd conversion as well $50
Standard R32 GTS Reo. $125
Standard R32 GTS Guards - Minor Damage No Rust $150
Standard Caster Rods - $30
Standard Sway Bar and Linkage Bushes - $40
R32 GTST Lower Control Arms - $150 a pair or $100each BUY THE PAIR AND SAVE!
S13 4stud hub assembly $200
280mm Non Turbo Rotors and Large Single Piston Calipers $200
- Will have rotors skimmed up for buyer if needed.
R32 Front Hub and Upper Arms - 4stud $150
R32 GTS Aircon Assembly $50 Pick up only .. to awkward to ship if you need lines with it.
R32 GTR Connecting Rods Set of 6 - Complete - 77,000kms $200 - Ideal for Rb25 build or RB2* Stroker
1x Sports Comp Boost Gauge - 2 5/8 - Psi Metric. With Cup and Bracket. $SOLD
PM if theres any parts ur after from the half cut ..... ie dash ..column cover ... glove box. throttle cable .. shit like that..... parts will be all available in teh next week ..when i start stripping it pending the start up of it.
Open to Offers - Shipping will be at buyers cost. Pick Up Prefered if local.
Located - Western Suburbs - Melbourne
Pm me or reply here im online regularly.
Matt
Edited by Angry
https://www.sau.com.au/forums/topic/127504-vic-r32-front-cut-parts-more/
I have a Rb30E flywheel for sale as well .. im told it will bolt up with most RB's .. but im not 100% on that ..
what is listed is what is for sale with the gearbox. nothing else. unless stated otherwise.
Oh and if you can put aside the air con lines, i will come and pick them upa nd pilfer any other parts my car needs.
Actually, is the shroud that goes under the windscreen in good condition. I had one lined up but with no car i wasnt able to grab it
