Originally posted by MrSnrub
By the way.... i know of this clay... it absorbs the overspray off of your paint work.
Better that buffing it out as buffing takes a layer of paint of your car :)
And the prize goes to MrSnrub!
The clay was mainly used to clean up overspray.. I know this due to a "Do it yourself respray of your faded side view mirror".. yes the respray turned out quite well unfortunately i didn't cover up the door enough... that clay stuff was magnificent... my detailer friend who i have mentioned before swears by it and uses it quite regularly!
  • Replies 70
Originally posted by R34
That's a shame Ben
Nice 'nowin you...see ya
Wasn't aimed directly at you Chris so no need to take it personally (i know it was posted after your post).
Was just saying in general there seems to be a lot of bickering going on around here. But im not a regular around here so if thats how you guys like it then thats great. Like your saying....if i dont like it i can leave.
Ben
    • 100% agree. Best bet on an RB will be NEO, but even it will be a long way off. Emissions is one of the big reasons car manufacturers went to DBW and constantly variable cams. When cruising, open the throttle right up, but reduce dynamic compression so low, that it's basically an unrestricted air pump moving very little air.
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
