post-26133-1153805648.jpgwondering if any one on here has seen/used one of these fumoto valves on their sump drain before as i am gonna get one to try.
and if any one has how well did it work was it easy to use etc?
the page is as follows.
www.fumoto.com.au
here is a pic
So it's like a quick release for your sump drain hole?
Looks alright, how much is it?
Also might just have to check clearances on lowered cars, but it reckons it only sticks out 10mm further than the stock sump plug....
they are $49 as in the pic or there is a model with a hose nipple on the outer end for $56 plus delivery which within aus is around $7 it said on the site, so it saves buying a new sump plug gasket at $7.50 a pop every time you drop your oil.
i dunno if they would do group buys or not as it is only a very recent release. i will try and work out how to put a direct link on the page and you can all see for yourself that there ghas been a fair bit of work in designing the thing and that they are now standard equipment on some car makers now.
but even so they are a good buy i reckon cos you can release the oil at its best time (when its really hot) so you get most of it out before it thickens.
i will contact them and see if they are interested. i have ordered mine already and am just waiting to hear back from them so will ask them when i do and will let you all know on here as soon as i find out
part number i have ordered F103 no nipple or there is F103n with a nipple
part numbers for all nissan ones are below with pricing for unit without shipping
Nissan All models from 1990 & on 12mm-1.25 F-103 $49
Nissan All models from 1990 & on 12mm-1.25 F-103N $54
Nissan All other models(up to '89) PF-3/8 F-102 $49
Nissan All other models(up to '89) PF-3/8 F-102N $54
Nissan Patrol (GQ) 16mm-1.5 F-108 $49
Nissan Patrol (GQ) 16mm-1.5 F-108N $54
Nissan Sentra('83 & on), Pulsar('83 & on), 200SX('84 & on), Gas trucks, 300ZX, Maxima('85& on) 12mm-1.25 F-103 $49
Nissan Sentra('83 & on), Pulsar('83 & on), 200SX('84 & on), Gas trucks, 300ZX, Maxima('85& on) 12mm-1.25 F-103N $54
Nissan Stanza Wagon('86 & on) 12mm-1.25 F-103 $49
Nissan Stanza Wagon('86 & on) 12mm-1.25 F-103N $54
Edited by oxford1327
honestly how hard is the sump plug to remove? the same plug on mine has been used about 20 times and never leaked a drop. they will either start leaking after a while or accidently get unlocked and dump all your oil, or get ripped off from a rock or something on the road.
sounds like a risk to me, and u dont get burnt by the oil if u pull it off, its easy to unscrew it and move ya hand away as its coming out without getting a single drop on yaself.
id rather put that $50 in my fuel tank :(
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
