Okay first start with a car that once had a vinyl roof. You have removed this roof only to realise it looks worse now you need to match up the colours!!! Rego is a bitch they want the car to look more presentable!!
Introducing the 10 min paint job. First buy some low sheen house acrylic, then a roller and you are away!!
Heres some pics of the success story!!
Simply brush touch in the parts you were to lazy to mask and your done!!
https://www.sau.com.au/forums/topic/127548-how-to-paint-your-car-in-10-mins/
the phots actually make it look better than real life if you can believe that!!haha
Had to be painted within 2 days or I had to start another new inspection for rego, so out came the roller. its not pretty by any stretch of the imagination but it does the job.
I can paint a car properly I swear, thought I would share something that had a few customers laughing as they walked into the shop!!haha
You know thats going to look like a chalk board once the sun hits that
Yeah wait till the frost gets at it also!! hahaha
240k all the way, plans for the car are rb26, r33 box, r32 rear cradle, with the gtr flares and some watanabes. Just need to get it regoed first so we can get it on the books with the engineer so all these mods will still pass when the car actually gets finished. I picked up the car a few years ago for $50, been sitting around while I have collected parts to do the conversion. I am leaving it looking like sh.t at first when the engine goes in...sleeper spec!!! hahaha, should be an interesting project dont want big power just want it to handle..
Already took her rally bashing a few years ago actually managed to break the diff, good value!!!
Edited by Fitzpatrick Speed Works
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
