Just spoke to my mechanic, and he has had NO trouble tunning the idle on an RB26. The placement of the vaccum/boost hose on the plenum is critical. He plumbs it into an existing nipple on the bottom of the plenum, as he beleives the MAP is more stable there.
https://www.sau.com.au/forums/topic/127579-wolfecu/page/2/#findComment-2365759
Wait until you get some decent sized cams.
https://www.sau.com.au/forums/topic/127579-wolfecu/page/2/#findComment-2365934
  • 4 weeks later...
Hey AL, was wondering where you got your Wolf 3D version 4 from and did they tune it???? ;)
I purchased the ecu from EAS Performance, Airport West (PM me for more details) and yes they have done all the tunning on the car. It is now running smoothly and am very happy with the results ;)
If you live in the East, go to Sabaddin (PM silva33 for address). He is also a Wolf distributor and have seen some very good tunes on various cars and ecu's.
https://www.sau.com.au/forums/topic/127579-wolfecu/page/2/#findComment-2433167
I have never seen a problem in our workshop with the Version 4 controling multiple throttle bodies even with very large cams.
The V500 is an awsome ECU, It can even control costant changing cam timing. The list of things it can do is almost endless. Just wait until you see the software :ninja:
Dont blame the ECU if you cant set it up properly like alot of workshops do!
https://www.sau.com.au/forums/topic/127579-wolfecu/page/2/#findComment-2435212
The V500 is an awsome ECU, It can even control costant changing cam timing. The list of things it can do is almost endless. Just wait until you see the software :huh:
The v500 software is downloadable from www.wolfems.com.au so check it out. Has heaps of adjustments. The datalogging isn't that great though. It looks like they used the v500 software to make the v400 just by removing some features. That's probably why it crashes a lot with a v4 ecu and the datalogging doesn't work correctly.
The v500 does look like a great ecu.
https://www.sau.com.au/forums/topic/127579-wolfecu/page/2/#findComment-2454753
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
