Can someone draw the driver a diagram so he can figure out what an apex is? It seems like its an accident when he clips an apex, rather than when he misses one.
Can we confirm if its an R8? Audi races them at Le Mans, and a hillclimb seems a bit tight for a car designed to do over 370km/hr down the Mulsanne Straight. And it doesn't sound like a 3.6L twin turo V8.
It looks more like a Westfield / Radical car to me...and if it had a worked bike engine then it would swallow gears like that.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2358294
Don't know about all the spectators standing pretty well on the road though as he comes blasting through... couldn't think of anything more dangerous
How about Rally, where the spectators / photographers stand on the course, jumping out of the way only when the car approaches?
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2358303
dont be too hard on the poor guy scathing! I would say he's not a pro driver, more just an owner/driver enthusiast. He does move his hand around the wheel alot which suggests to me that he hasn't had a lot of experience in prototypes or open wheelers. I didn't think he was doing too badly overall. yes he is pretty wide a lot of the time but that may be for safety as much as anything and it may be the quickest way through the course in a car like that. it certainly is an awesome hill climb course that's for sure.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2358386
Hey, if it was me in that thing you could probably drive another open wheeler between me and the apexes :wub:
I probably wouldn't be posting it all over the Internet though. :D
But that hillclimb looks a lot more fun than Huntley, which is the only hillclimb I've ever done. I'd love a crack in it in my car.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2359312
You would use a totally different line when raciong down a open road by yourself, compared to racing on a track with a need to defend a racing line.
His Class time on the day would decide if his good or not.
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2360295
And the biggest difference between a hillclimb and a circuit is how many laps you get to do in a row :angry: this run is pretty long/lots of corners it would take a while to learn perfectly.
But after doing a few hundred laps of a track you could do it inch perfect in your sleep
https://www.sau.com.au/forums/topic/127619-hill-climb-vid/#findComment-2360695
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
