Definitely will solve your misfire. Providing of course that the coils are the problem. But 99% of the time coils are the cause of misfiring.
I had the same problem on my R33 and just recently bought splitfire coils from Lynx corporation in Erina central coast. Also put in Splitfire triple platinum spark plugs. I now have no more misfiring and much crispier throttle response. It revs a lot smoother as well.
So in my opinion worth the investment.
Paul.
Have you tested the coils?
If they are not faulty, then its a plain waste of money. Splitfires are only as good as good condition stock coils
It could is a multitude of other problems, dirty AFM, dirty connections to the coils, plugs etc etc etc
hey all
iam thinking of buying split fire coils for my rb20det will the get rid off the misfire above 4000 rpm and make it run smother.
thanks
Dan
Spend $20 and change the plugs first. 99.9% of the time misfiring is caused by plugs.
:dry: cheers :(
possibly get new plugs and run a smaller plug gap. helps firing and may make your need for coil packs go away. get a workshop to gap them if you dont know how to. i dont know how small a gap you shoud run ither sorry
correct me if im wrong anyone
splitfires are cheaper than standed coils if you shop around . i just brought a set from perfect run 580 bucks delivered to my door in 4 days from japan
Edited by mid life crisis
You paid $100 for postage?!
They are around $486 converted from YEN and they do delivery by the weight, and coil packs are 1.8KG which is ~$40 to post to Australia. Should be able to have them for $526.
I just ordered some stuff from Perfect Run, the shipping was $55 which is equivelant to 2.5KG
Just out of curiosity, if you happen to have a problem with one or more of these coil units that were imported how do you have the warranty sorted out or coils replaced?
    • The way they do the test you would be very lucky to ever hit any cell that isn't aiming at 14.7 This was my result... Really not sure what's going on there!
    • I have a projecta one.  A proper trickle charger can be left attached 24x7, that's what the trickle bit is about.
    • With an electronic boost controller, there are settings available to limit overboost.
    • Ah ok, my tuner did adjust something on the percentage cycle on the boost controller, instead of running at 40% the tuner put it on 20% to compensate for the overboost, can't remember what it was. Not duty cycle don't think, and told me if it keeps overboosting, it's going to be something else. I think he mentioned the turbo actuator.
    • Which trickle charger does everyone use? I'm going on holidays in the future, and last time it was left for a couple weeks off twice per time, and don't want to keep doing it to damage my battery so looking to have something hooked up to the battery which connected to the car, as I need to keep my immobiliser system on. If the battery goes flat it will mess up my security system (already happened once) I was looking at the following, so can have someone turn it on every couple of days and run it overnight then turn it off)   https://www.supercheapauto.com.au/p/noco-noco-genius-5-battery-charger-6v-12v-5-amp/648987.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=1   https://www.supercheapauto.com.au/p/century-century-cc1206-xli-12v-1-3-6a-9-stage-battery-charger/693006.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=30   though these don't say anything about trickle charging, don't want it to overcharge the battery.
