Definitely will solve your misfire. Providing of course that the coils are the problem. But 99% of the time coils are the cause of misfiring.
I had the same problem on my R33 and just recently bought splitfire coils from Lynx corporation in Erina central coast. Also put in Splitfire triple platinum spark plugs. I now have no more misfiring and much crispier throttle response. It revs a lot smoother as well.
So in my opinion worth the investment.
Paul.
Have you tested the coils?
If they are not faulty, then its a plain waste of money. Splitfires are only as good as good condition stock coils
It could is a multitude of other problems, dirty AFM, dirty connections to the coils, plugs etc etc etc
hey all
iam thinking of buying split fire coils for my rb20det will the get rid off the misfire above 4000 rpm and make it run smother.
thanks
Dan
Spend $20 and change the plugs first. 99.9% of the time misfiring is caused by plugs.
:dry: cheers :(
possibly get new plugs and run a smaller plug gap. helps firing and may make your need for coil packs go away. get a workshop to gap them if you dont know how to. i dont know how small a gap you shoud run ither sorry
correct me if im wrong anyone
splitfires are cheaper than standed coils if you shop around . i just brought a set from perfect run 580 bucks delivered to my door in 4 days from japan
Edited by mid life crisis
You paid $100 for postage?!
They are around $486 converted from YEN and they do delivery by the weight, and coil packs are 1.8KG which is ~$40 to post to Australia. Should be able to have them for $526.
I just ordered some stuff from Perfect Run, the shipping was $55 which is equivelant to 2.5KG
Just out of curiosity, if you happen to have a problem with one or more of these coil units that were imported how do you have the warranty sorted out or coils replaced?
    • Hey everyone, just wanted to let you know about an app I use to track the modifications, repairs, servicing etc I do to my R33 GTR. You might like to use it as well. I'm biased because my son just wrote and released it! But I think you might find it useful to... https://trackmymods.com
    • Hey everyone, been on here for a while, but never introduced myself before. 1st import was a R32 GTS Type M, then R33 GTS, now R33 GTR - each one sold to help pay for the next one. Over the years my son has seen me modify and do changes to my imports and was one of the reasons for him to build an app for car enthusiasts like us. (He can only afford a 2007 Honda at the moment, but he'll get there!) Anyway, bit of a proud Dad moment as he's released an app that I use and you all might like to as well. https://trackmymods.com
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
