Hey Lads
Selling my 1990 Nissan Onevia.
RB20DET conversion
Polished Cam Covers
HKS2540R turbo
Oil Catch Can
Blitz Dual Turbo Timer
Full 3inch exhaust with twin magnaflow mufflers and is very quite but has a very nice rumble!
HKS Pod Filter
600x300x76 FMIC Brand New!!!
PBR RPM Heavy Duty Clutch
HD Coilovers
Whiteline Sway bar
Whiteline Camber bushes
Pineapples
Z32 front Brakes with DBA slotted rotors
S15 Front Seats
Door Trims and Glove Box Re Trimmed
White Dials
Central Locking Imobiliser
Apexi Boost Guage
Tinted Windows
Bosch 044 fuel pump
18 Inch Konig Unknown Rims (Cost $3000 new 2 months ago)
Clear Tail Lights, also have the stock ones which will be supplied
Full Vertex Kit
Carbon Fibre GT Wing
Full Silver Re-spray with a nice mettalic sparkle which is less than 6 month old
Pioneer HeadUnit, front speakers and back speakers, pioneer 1000w sub with 800w monoblock amp
Will trade for other cars - but mainly looking for a non-turbo silvia.
Anything else you would like to know, just post or PM me :DLooking for around 18k
Makes 170rwkw's on 7psi (for all who know, this is alot for 7psi!) and 210rwkw's on 12psi!
Email: [email protected]
Mob: 0437137238
Cheers
Chris
Advanced Motorsports
https://www.sau.com.au/forums/topic/127671-nissan-rb20det-s13-onevia/
hey mate, a few things you might want to know about the car.
it also has 550cc injectors.
Dr Drift remap computer.
Upgraded Brake Booster
Aslo it is a single spinner. No LSD as it was converter from a CA18DE.
How do i know this, i was the orginal owner who built the car.... as shame it has been kitted and stupid T-wing.. good luck with the sale.
Cheers
Dave
  • 3 weeks later...
