yesterday i changed the upper and lower radiator hoses(very old) the radiator cap and the thermostat.... took it for a drive and thrashed it a little !! but the car still seened to be getting quiet hot ...... and after i unplugged the heat sensor and put it bak in the heat said half in the guage,,,, something is a miss and i just cant figure it out !! sensor? head? and there doesnt seem to be a build up of pressure on the hoses?? me is a little lost .... have i done something wrong ??
https://www.sau.com.au/forums/topic/127679-overheating/
Obvious question is did u put the thermostat in the right way and did u get the right one?
Are u using an overflow bottle with the rad?
Is the coolant level stayin constant?
If all ok replace the water temp sensor.
hey thanks for the reply, air flow bottle?
coolant seems to be staying level now, and yes the thermostat is thew correct one and its in the same way the other one came out !! im hopeing it isnt the water pump... could that also be it !! and i was planning on doing the water temp sensor on the weekend.
https://www.sau.com.au/forums/topic/127679-overheating/#findComment-2359920
how do you know it's overheating?
The "normal" position on the stock temp gauge will sometimes change when you install a thermostat that opens at a different temperature.
Perhaps get an aftermarket water temp gauge to see where you're actually at more accurately
Anyway, if it's definantly overheating and you've ruled out the thermostat, then it's probably the water pump.
https://www.sau.com.au/forums/topic/127679-overheating/#findComment-2360072
ok, but if it was the water pump wouldnt the car idle differntly? ot would the cur run differently? cause the car still kicks well
https://www.sau.com.au/forums/topic/127679-overheating/#findComment-2361769
it would idle the same
try driving it without the thermostat but of the bearing in the pump is f**ked it fan wont keep running straight, it wont run true to the engine
my mates fan smashed 2 radiators before he fixed his pump, bearing was screwed and the fan moved enough to foul on the radiator (r31 skyline, same shaped pump with more fins inside)
https://www.sau.com.au/forums/topic/127679-overheating/#findComment-2361934
ok the coolant isnt staying constant, it builds up in the overflow, and ends up being like 2 inches hight then it was b4 driving it !! im not driveing iit to the stage of it over heating !! just been taking it on test drives ....
https://www.sau.com.au/forums/topic/127679-overheating/#findComment-2362015
ok further info !! was doing a little more work on the car today !! took it for a drive !! still doesnt seem to be much pressure in the radiator hoses?? car is running fine !1 ideling fine, but AFTER ABOUT 30 MINS OF DRIVEING the heat started to rise !! the overflow keeps filling to the stage where its about to overflow?? im starting to get worried... :teehee: its starting to look like the waterpump i think??
if so how much is a good estimate for the pump and work ?? anyhelp would be benifical
https://www.sau.com.au/forums/topic/127679-overheating/#findComment-2365119
Pumps have been known to rot out the impeller blades because idiot (previous / Japanese) owners don't use proper coolant.
Pump is around $100. Job takes a (leisurely) couple of hours.
You need to remove the radiator, so while it is out, get it thoroughly cleaned.
https://www.sau.com.au/forums/topic/127679-overheating/#findComment-2365779
cool thanks for that... i think that job is a little passed my knowledge, so i might have to look into getting it done bysomeone....
https://www.sau.com.au/forums/topic/127679-overheating/#findComment-2366737
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
