you can remove rust by electrolysis with a low voltage, and aparantly it works well
but you need a solution (washing soda, baking soda or lye mixed with water) and the part has to be immersed.
so it smells like bs to me.
It's for those braindeads who regularly takes their car to the beach thinking its a Hovercraft... especially when their cars' brand, ehm...I mean Hovercraft, have the same starting alphabet "H" with a Hovercraft.
Um, actually, any of you guys that are laughing at this device are very wrong.
It is corrosion protection by applied voltage. Corrosion is a chemical process which can be prevented by many ways. It is a reaction that requires water and oxygen. Obviously painting it or covering it so there is no oxygen will prevent corrosion.
It can also be prevented by attachign a sacrificial anode - like on big ships. A block of magnesium is attached. Same as in your big water heaters.
Applied voltage is another such method. It sets up a galvanic cell.
It's not something that you can just bung on any car. Like it's not "just a ground wire". It is a special device. All panels are linked to it. It actually works. I have tested it using cast iron.
Ford Falcon AU comes with this from the factory.
Research it before you knock it.
About the only thing I could think of it doing would be inducing a galvanic voltage too the chassis, but that shit is normally only done too boats and stuff with a zinc surface on it.
ed- read the above guys post, he knows more about it :happy:
Edited by MK2
has been researched mate there shit ive got a mate that works for batteryworld and they admit they dont work as they sell and test them
Hey guys, sorry if i seemed a little rough up above.
As MK2 said, they are normally used on boats, wharves, buildings by the sea and cars in snowy areas/rainy (chemicals such as salt added to the road surface increase corrosion rate).
I dunno how good that system is. It might be total shit as you said, or it might work. Never tested it.
I have a friend that regularly works on boats, and appplied voltage is the bees knee. It works very well.
Once again, sorry.
fat31, I wouldn't expect those ones that b82rz world sell to work very well, because they're cheap.
I can tell you for a fact that the one on the au falcon doesn't work very well because there is rust on one of my panels.
But if done properly, it works very well.
Cheers
Nate you obviosly didn't do chemistry in High School?
This was covered in my year 12 chemistry class, and it works. And that was 7 years ago now.
Rhett
Rhett
obviously not, as i popped this thing open today, and all that was in it was a small circut board with some resistors to make the lights blink.
We have cathodic protection on the oil and gas pipelines at work, which operate on the same principle. So theoretically they should work. Whether this particular one works is an entirely different story though!
You have to push the red hexagonal STOP button for it to actually stop your car from rusting. It will stop your car from rusting as long as you are pushing the button. You cannot use tape to hold the button down.
Seriously though, if it was going to reduce rusting by applied voltage you need a complete circuit. Since the body of the car is connected to the battery negative, you need another surface for the positive side. This has to be connected by an electrolyte (assuming rain, in this case). So what's the missing surface?
i work at toyota and they are sold to ppl when they buy a new car
its an aftermarket option like tint and fabric protector
Yep the oldies have had it on their last 2 cars.
They origionally owned an 80series landcruiser that didn't have one fitted and showed signs of rust after 3 years.
They sold it and bought a nissan patrol and had one of these gizmo's fitted, funny enough the car had rust on it from factory, it went back, they got another, that was soon traded in for a new 100series landcruiser, the old toyota 4wds definitely have it over the patrols i must say. :D
The new landcruiser also has one of these gizmos fitted, no rust yet and its 1yr old, see's salt water (boat) every weekend.
http://www.ruststop.com.au/
I did my apprenticeship on shipping, There are guys who specialise in this area (those blocks are Zinc) and get an iron block with sea cooling to have zero corrosion, They use small zinc anodes inserted into the motor cooling passages and an electrical current to protect the inner sufaces. Of course the annodes wear away reguarly and require yearly checks.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
