I did my apprenticeship on shipping, There are guys who specialise in this area (those blocks are Zinc) and get an iron block with sea cooling to have zero corrosion, They use small zinc anodes inserted into the motor cooling passages and an electrical current to protect the inner sufaces. Of course the annodes wear away reguarly and require yearly checks.
In that case you have an easy complete circuit though.. The zinc and iron block are your two electrodes and the coolant is the electrolyte.
The only electrolyte I can see with this "rust stop" thing is rainwater.. which would do a marginal job at best even if the car (and zinc rust stop device) was covered in a film of water (which it wouldn't be).
You'll find alot of 4wd uses those device, been a 4wd owner who frequent fraser Is. alot, for it to works properly the protected item has to get wet from time to time, otherwise, it's as useful as tits on a bull. It uses the same voltage correction technology as steel ship. The navy runs steel vessel and has a much more complex abeilt same theory set up.
heh anodes will crode before any other solid material under salt water. Considering you run salt water throught your engines on boats.
I think rust or corosion is caused by ferons (excuse spelling) leaving the metal.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
