i had my rb25 rebuilt (with stock parts) a few months back. We didnt change anything on the pfc during the run in stage.
Once i had done 1000km and it was way past the being run in stage my tuner slaped it on the dyno and made a few minor adjustments.
well just get it tuned after you bed the rings :angry:
nice and easy really
Rings wont bed if you wash the bores. Just run it in on the dyno - get them to do a bottom end tune up to 3 or 4 psi of boost and 5000rpm.
Edited by rob82
With the new motor I'm going to run 440cc injectors and z32 afm although these could be fitted after it's initial run in.
Shouldn't I do something to the tune before I even turn the key?
Would it even run with the rb20 tune?
How long does it take to run it in on the dyno?
It sounds expensive at $120+/hr
can't help you with the power fc info, (still trying to sort mine out!!)
but we used to run in 400HP+ 11 sec V8's in less than an hour on the dyno, they can put the engine under high load at moderate rpm's, half a dozen run ups like this is more effective than you driving up a hundred hills in the next month.
after the dyno session the engine is basically run in, from memory, you just need avoid 75% & above RPM range for say 500k's, but this way, the rings are definately bedded & you can 75% flog it straight outa the box.
Prolly a mineral oil (or semi synthetic) for start up & initial dyno work, then full syn after 500k's
Talk to your local dyno guru, he will surely give you the right routine! It's a darn site better than having to do so many rpm for the first 500, then so much for the next 500 & so on.....................................
The problem is i live in a regional center and there is nobody with a dyno locally.
I would have to trailer my car to the goldcoast or brisbane but I don't know who to trust.
Booster, know how you feel brother...................aint even a dyno in the COUNTRY where i live.
i think your biggest problem is going to be loading the FC with RB25 stuff, good luck, i wish i could help.
Could you just factor in a 30% fuelling increase into the pfc and see if it starts and immediately check the afr and trim it accordingly?
No. The PFC uses airflow to calculate fueling anyway, if you're running a larger engine it will inject more fuel. However it will probably run rich as shit because on an RB20 pulling that much air at those revs would be very high load, so you will wash your bores down. Adding 30% more fuel will make the problem worse.
You've just spent a few grand rebuilding an engine, spend a few hundred bucks getting it put on the dyno, they can start it and get a base tune going and do a few ramps up to 75% redline at a few pounds of boost like rob82 said.
You should always run an engine in a proper state of tune. Anything else is just brainless.
Like I said the rings wont bed if its too rich as it will wash the bores - so run it in on the dyno and make sure your mixtures are right.
I was hoping he would be using a builder/workshop to run it in etc so they "should" know whats needed
:D
Here’s what I would do;
Use the PFC
Drain the tank and put some Shell Optimix Extreme 100 ron in it.
Stick the 444 cc injectors in it
Reduce the injector duration by 30% (close enough for 444 cc’s / 270 cc’s)
Start it and check the exhaust pipe smoke
If it’s thick and black, then take another 5% out of the duration
Let it warm up at a fast idle, say 1200 to 1500 rpm till it gets to ~80 degrees
Drop the idle to normal (~750 rpm)
Then check the exhaust pipe smoke, smell it
If you can smell heavy unburnt fuel, then lean it off 2% at a time.
The PFC will go into closed loop running once the unburnt fuel smell is gone.
Keep the boost low, take it for a drive and watch the knock readings on the Commander.
If you are getting ANY knock, retard the ignition until it disappears
After 15 minutes or so, go home, open the bonnet, pull up a chair and have a beer
Once the engine is cooled down, pull the plugs out and have a look at them
They should be dark brown, but not black.
If they are not black, then set off early in the morning to the dyno.
Try and make sure you run closed loop cruising as much as possible
By the time you get there it will be run in enough for a mild tune.
:) cheers :)
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
