hey there guys. i am a newbie to all this audio stuff, but i can learn very easly. anyways i am planning to do a custom boot, dash and door panels with fibre glass. was just wondering if any of yous could help a brother out and give some info on how to mould and what i should be using for best sound and strength.
thanks heaps
Gordon
https://www.sau.com.au/forums/topic/127754-custom-style/
yeah but i am in wa
Dont you have cabinet makers etc in the west?
But really, to describe how to custom mould dashes etc isnt exactly the easiest task, in fact a botched custom job will look awful.
My advice, if you dont know what you are doing, dont try to get advice in words from a forum. Seek out the help of a professional custom installer, pay for his/ her time and end up with a car that is worth showing off, not hiding in shame.
Take it from me, i've only been in the game 11yrs or so...
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2363336
yup, of course .. build a frame then lay it with carpet or something :)
Best thing about custom - if you do it and yo dont like it change it
Worst thing about custom - if it looks shit its your own fault not someone elses
Best thing about tailor made - Will look sick in the end
Worst thing about tailor made - Sometimes costs an arm and 2 legs + you might not like bright pink fibreglass with rainbow neons
(just stating the obvious)
Look at some examples of cars dude, checkout a civic or two, normally riced up to the max, and have some sweet installs. Even go see one, eg. look in autotrader for a civic with a custom stereo and pretend to buy it and checkout what he did.
OR checkout AUTOSALON this weekend :D hint hint
Edited by Hypn0tiK
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2363533
You deadset on fiberglass? i made an entire mdf floor in the boot of my 32, screwed the amps, wires and sub box to it then did another layer of mdf with vynal on it and it looks schmicho! much much eaiser than fibreglass...
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2364611
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2364613
Not sure if mods will allow an external URL, but for car audio tips and making custom pods and stuff out of fibreglass, check:
www.caraudioaustralia.com
There are plenty of tutorials on how to do it properly.
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2366735
yeah that site is awsome, helps a lot. looks easy. and it explains a lot
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2367546
OR checkout AUTOSALON this weekend :) hint hint
hey, how did you get the skyline badge/strip on your boot to light up? looks awesome! i assume you bought it? Where from? and how much?
https://www.sau.com.au/forums/topic/127754-custom-style/#findComment-2369175
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
