ok quick replies to questions today.
N1GTR. no the hose clamp will not be included in the packet a i am not gonna be postin them out, but the hose clamp it self should be bout 40cents at any hardware store or automotive shop and will be of size 12mm to 18mm as this is the size i used.(i "found" mine at work though hehehe)
SATANIC. the differences would only be in the thread size of your sump and as it states in the listings of engines on page 3 of the thread that most nissans are the same, a for the number tag it would be to identify you as the payer when the deposit is made, for example say they allow you to only put a string of numbers next to the deposit receipt number, some banks allow letters and numbers so that the payee can tell who it was that deposited the cash, somethin like this
deposit of $41 from satanic(real name) at blah blah bank on this date receipt number 6549613 with number tag 55689.
you then pm me with the details of the transaction/amount/receipt number and the number tag you put with it so i can identify you as the payer when i check the balances etc.
hope this makes it a bit clearer for ya but if not lemme know k
Edited by oxford1327
  • Replies 107
Posted Images
Hi Guys,
Just thought I'd check on this group buy and answer a few questions.
Thanks to Oxford for setting this up. I'm sure you guys will enjoy the valve.
A lot of questions are answered here http://www.fumoto.com.au/info.htm
Some of these questions have been answered, but I'll confirm the answers.
Yes I'm in on the group buy... can you find out if the nipple is removable?
There are two versions, non-nippled and nippled. The nipple is cast into it so, no, it's not removable.
Interested, but id like to know how hard the spring that holds the arm is So there is not a chance of it swinging open by itself
It's double-action, so you have to push it "up" then across through 90 degrees to have the ball valve completely open. It is still quite stiff. No way it would open due to vibration or hard jolt.
Will these fit an RB26, I remember reading somewhere that the magnetic ones you get don't fit the 26's sump, are these the same or are there different parts for each?
Unless the sump drain is recessed or there is a cross member/ sway bar in the way, there will be no problem
fitting the valve. Take a look at the pics and you will get an idea of how it mounts. These are not magnetic in any way.
All late model (1990 on) accepts F-103 (12mm-1.25). Pre 1990 - F102 (PF-3/8). Please check your sump plug if unsure (yes, it will be a pain, but you only have to do it once).
Will also fit RB25.
For honda s2000
Please note, Honda S2000 takes an F-106 and requires an ADP-106 (adaptor to allow the valve to clear the sump). This will add significantly to how much the valve sticks out, please be aware of this. I estimate 40-50mm in total.
does the lever have to be held open?? or does it lock into place??
Locks open so you can leave it to drain.
Can you find out what postage costs are - I'm in Perth...
Standard delivery charge to anywhere in Australia for any quantity. Included in your price.
one question. since its a ball valve and its underneath. exposed to dirst, water ETC. Will the ball valve works in the long run? if this matter is clarified i want one as well. Will it fit the RB26 engine ? Let me know.
If you get crap in it, hose it down, it won't mind. Stainless steel ball. If it leaks, I'll replace it...even in 10 years. Keep your receipt.
another quick question. Will the quick realease valve be sticcking out abut 1/2" to 1"? If one has tje car low will it be risking of hitting a bump with the valve and rip the whole thing off? Let me know
In total, it should only be sticking out 10mm more than your sump plug. As well, it will be on an angle so the actual distance from the ground is not excessive.
oxford are you able to put up a list of motors that this fits please?
http://www.fumoto.com.au/sizes.htm
Can it come with this? (Hose clamp)
Personally, I don't think you will need it (unless you go offroad in the Skyline), but for your own piece of mind, you can add a hose clamp, or use a small (1-2mm thick) cable tie. I can include some cable ties in your group buy (Oxford - please remind me).
Any other questions, please don't hesitate to ask.
Cheers,
Jack
EDIT: Had too many quotes.
Edited by Fumoto
Yes i read the whole thread and by the look of the chart on page 3 they will fit SR20
But just want to make sure, Will these fit a SR20?
If so you got another.
Yes, they fit SR20. Same F-103
Oh, in case everyone didn't read my reply to Oxford on the first page, the prices are for F-103, non-nippled. I assumed that everyone on Skylines Australia would be getting one for their Skyline.
If you are getting one for a car other than a Skyline, please check the part number and price for that vehicle and let Oxford know. If it is originally $49, then you will get the same discount. If it's more, or you need an adaptor (eg. Honda S2000), then the price will be different.
You should check your bank to make sure payments have arrived..hahaha I put in the wrong account number, lucky it came back to me :O
All fixed up and Paid with the correct account today :laugh:
Alright well I took a look under the front of my Stagea and lined up what it there and at what levels and here is my interpretation:
So here are the explanations:
RED - This is the bottom most part of the lip on my front bar
YELLOW - This is the bottom most part of the actual front bar
GREEN - Front part of the front subframe
BLACK - I dont know what the name for it is, but it s huge thick peice of metal that runs just behind the sump
PURPLE - The Sump itself
BLUE - The sump plug
So yes if anything hits the sump plug it's going to hit that big black thingy too, but I noticed that there is a small hole in the subfram bit that runs in front of the sump plug, so I might just bolt a peice of 5mm thick steel there that protrudes down a bit o add that little bit of extra protection.
Does it cost extra for the nipple version?
Yes, the nippled version is $4 extra. Unless your sump drain hole is behind a sump guard (and you couldn't be bothered taking the sump guard off every time you change the oil), you don't need the nippled one (to attach a hose to). Just open the valve and let the oil drop straight down into your oil pan.
Yeah I would rather attach a hose but that is just me :rolleyes: for ~10% extra on the price, just for the nipple........ meh I can do without.
How much are the units normally without postage?
Horses for courses. Just be aware that the nipple adds an extra 18mm to the valve's length.
Non-nippled with out postage is $49, nippled $54. Postage is normally $7
So at $41 delivered, that's not a bad deal.
Sorry, no defensiveness intended. I'm here to answer all your questions.
And you've done well - well done and cheers for the group buy (Ox and Fumoto)
the big black steel bit you are referring to ska is the main crossmember for the front section of the chassis.
in the pics i took under my car you can see the crossmember just behind the drain i have installed, so this should give you a clearer indication of where it will be situated once you install it
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
