  • Replies 107
Posted Images
the lever is like any other ball valve once it is turned it stays in place. so you don't hafta hold it just unlock and turn then continue about the other stuff req'd for services etc.
well guys my valve arrived in the mail today so will be changing my oil on wednesday and will update everyone on whether its a good thing or not eg: ease of fitment, how secure it is when in the closed position etc.
it certainly looks the goods though!
pending oxfrod1327's feedback im in
post-26133-1154492446.jpgpost-26133-1154492498.jpghello all.
well i installed the valve today and it works a treat, as i always buy some cheap synthetic oil to flush through and make sure i get most of the gunk out before puttin the new motul in.
once i got the original oil out i installed the new valve made sure it was closed off and refilled the engine with the crappy oil,started the engine and let it idle for bout five mins to check for leakage etc. before taking it for a quick spin to load it up a bit so as to circulate through the whole system.
i then put the car back on my hoist and let it out again, it was surprisingly easy to use and if you look from the front of the car underneath you cannot even see the valve so i reckon there is bugger all chance it can be sheared off as some people feared.
all in all i give the valve a big thumbs up and my old man saw it and reckons its a good thing as if you really wanted to you could drain the oil without having to even jack the car up as there would be no requirement for tools just a pan and some ground clearance.
i will try and get some clear pics of the install and how much of it you can see under the car from on your knees etc. and post them up for the doubters. in the pics added you can see that the cross member is the lowest part, so if thevalve was to be gettin torn off there is a fair chance that you are already on the way to a massive repair bill when you go back and pick up your engine off the ground hahaha
Edited by oxford1327
the buy will be getting done at the end of this month so as to give the most oppurtunity for people to jump in on it, we already have almost 20 people that have chucked their hand up for one so as soon as i get my end of it sorted i will be listing payment details etc.
as listed in the first couple of posts if we get over 20 buyers the valves will be $41 including delivery.but i reckon the more the better eh?
Can you find out what postage costs are - I'm in Perth...
as listed in the first couple of posts if we get over 20 buyers the valves will be $41 including delivery. but i reckon the more the better eh?
So I reckon more than 20 buyers will be easy to get!
Make sure you PM everyone when time comes
list of interested parties has been updated in the first post if people are interested it looks as though we already have 18 and a couple of maybes.
and its only the 6th of the month.
i am gonna go to the bank tomorrow and organise an account for this to be paid into and will post up the details as soon as i can
one question. since its a ball valve and its underneath. exposed to dirst, water ETC. Will the ball valve works in the long run? if this matter is clarified i want one as well. Will it fit the RB26 engine ? Let me know.
Guest
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
