  • Replies 107
Posted Images
hello all
just to let you all know i finalised the purchase of the valves today and they should all be delivered by weeks end hopefully as promised.
cheers oxford
Got mine today awesome.!
Will leave trader feedback :)
fitted it today
i put an extra rubber washer thingy on so that its angled down a little more and wont shoot the oil out sideways when i empty it
I recieved mine today :laugh: Thanks... BUT, I thought they had a double locking like where its sits in closed, I thought there was another one on the other side to lock it in Open :laugh:
wont have to worry bout a lock holding it open as it will hold itself open whilst draining, they are a fairly tight tolerance valve so they will stay put in the position you choose until you switch it back.
  • 2 years later...
Guest
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
    • I wonder if these would be discounted when they have their big sales? because if so would be a great time to actually buy them could even end up cheaper than buying from quickjack in the end.
